ive got a broken stud in my head for the exhaust manifold... its the very rearmost stud and ive already had a go at removing it, i drilled out the inside of the stud and tried to use an Ez-out to get it out but it snapped off in the hole that i drilled... im not having much fun here :P
what are my options?
https://www.sau.com.au/forums/topic/193653-broken-manifold-stud-removal-tips/
is there much of the easy out sticking out the hole? could try welding a nut to it and using a spanner. or go a get a right angle drill, about 10 drill bits (or if your any good at sharpening them do that instead), and some patience, and drill the EZ-out out. use right twist drills for this and hopefully the if the drill grabs it will loosen the EZ-out and screw it out.
to remove broken studs i always use left twist drill bits, when your drilling the stud the drill bit also unscrews the stud at the same time, easy.
a couple more ways would be:
we sometimes remove broken taps (same steel as an EZ-out) at work with an oxy/acetylene kit, with a really small tip heat the tap till its really hot, then turn the acetylene off, the oxygen blasts the tap out.
a costly method would be with a spark eroder.
or remove head and get it milled out.
Leave it for the experts, you're only making matters worse.
I had exactly the same problem, same position.
I found it while the engine was out so I tossed it in the trailer and off to the local muffler fitter.
He MIG welded a washer to the remains of the easy-out and then welded a nut to that washer. After a couple of attempts, he unscrewed the broken easy out. (Our problem was we didn't know if it was an easy out or a drive in type of stud tool)
Then he MIG welded another washer down onto the remains of the broken stud, and then welded a nut to that washer too.
It unscrewed easy peasy from all the welding heat.
He's a great welder with steady hands and eyes that still work. Whole job cost me $25.
I'd rather remove an engine/gearbox than pull the head with all the associated gasket costs etc of re-fitting the head.
thats all well and good but in my case the stud has snapped off inside the head, so that eliminates welding something onto it to remove it...
No mine was exactly like that, recessed inside the head.
Just takes a steady hand and good eyes with a MIG.
cant help you with the stud, but i have a good stress relief teqnique for you. Try throwing a spanner as hard as you can against a brick wall, then drink too much jacks and coke. Thats what i did and the problem disappeared right up until the next morning.
it just takes time and patience, and you'll get it. Since it the most rear stud it might be worth your while in getting a right hand drill adaptor like it was said above. Just drill the inside of the stud, slow and steady and peel the stud out and run a tap through to tidy up the thread.
Its a pain in the ass but nothing an hour with the drill and a few drill bit wont fix, good luck :nyaanyaa:
Edited by R34GTFOUR
what i have done in the past is used a drill bit about the same size as the stud and tryed to get the drill to grab and spin the broken stud done to the bottom of the thread, once it is down the bottom you can tap out the outside of the thread and then with a bit of lube the stud will come straight out with an ez out.
happy hunting. :nyaanyaa:
Listen to Zertek, the mans a god! :nyaanyaa: rofl s**t'a'copters
deary - if u cant jimmy it out... leave it to the professionals who qoute time and money... did i just say that? Faaark meh
happy hunting. :worship:
if you use a left twist drill instead of spining the stud down to the bottom of the thred it spins it out :nyaanyaa:
if your in adelaide ring up captain thread he is a mobile guy does it in about 20 mins i had 3 broken studs he had them all out and cleaned up the threads in about a hr cost about 90 bucks from memorey
I have had 2 snapped and recessed studs removed using this method. I'm pretty sure this is how most exhaust places would do it too.
yeah, but the rear stud is in an absolute prick of a position and you would have to be a magician to get a weld in there, let alone a decent one
no1 use crc when removing exhaust studs anymore?
n make sure when u put ur new studs/bolt in u put some never seize on them so they well never seize again lol
jus ring the tread doctor or another such mob pay the cash n be done with the headache (n im not 1 to throw money around but sometimes with the headache VS the cost, the cost wins...)
i had 7 broken studs on an RB30. Drilled the whole way through the broken stud, sprayed some WD in behind the stud through the hole i just drilled then proceeded to drill the next and spray etc etc. after all were drilled and sprayed i got a TORX bit with plenty of teeth on it (like a double hex allen key but it adapts to a socket so you can ratchet it out) that is just a bit too big for the hole, the tighter the better, tapped it in with a hammer and then first wound it in half a turn then wound it out all the way. if the TORX bit slips in the stud drill a bigger hole use a bigger bit. I've found extractors to be very brittle and easy to snap, the TORX is both hard and strong so the chances of it braking off in the stud are slim to none. I understand space is at a premium, but if you can get an angle head drill in there your set. Hope this helps.
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
