skyline
good - a better daily driven car, more comfortable and refinement. better off boost power due to 2.5L and big brakes.
bad - heavy, higher maintenance, had to spend more on mod if u want to go REALLY serious.
180
good - better handling, touch faster, u won't see many around.
bad - noisey, roomy.
i upgrade from silvia to r33 as i think silvia is too small for me(me,gf & sister) and it's damn noisey, not good for daily driving.
but as my gf & sister got the own car now, i would like to go back to silvia(S15) as it's cheap to reach my aim of performance(low 12sec car)
Originally posted by strange
hi guys, considering whether to buy a strawberry face 180 or Skyline R33 GTSt series II, but can't really decide, somebody explain the pros and cons of these 2 in your own opinion? Thanks in advanced..
Cheers!
And you are on a Skyline forum asking this ??
Cheers
Ken
I used to have a strawberry face... jus the look on ppls faces when you tell em its a harchback 200sx is enuff in itself.
R33's are as common as camries, get sumfin different. I got my CA18DET 180 for $13k (like 3 yrs ago) and then got a bomex kit from japan for about 4k (from a wrecker) bit of patch up etc shipping and for around 19k I was pushin a pimped up car.
As far as pros n cons, the GTSt is more up to date, seriousy the interior of a 180 sux dogs bollox, so uncomfortable, the seats are shit (had fake recaro's in mine but i'm talkin bout the stock ones). All the controls are on stalks like really old outdated 1988 cars (even the R32 din have them).
So yeah, if you're after creature comforts get an R33 its the biggest whale... i mean car as far as 2 door under 1.3tonne imports go. :)
If you're more of a mods person, get an latemodel 180sx with a black top SR20DET in it, it'll give you the most bang for buck... more than an R33. it really responds well to mods as well. I pulled 160rwkw out of my 1.8L, so meh.
Originally posted by Maxx
skyline
180
thanks for the info dude.. :(
So yeah, if you're after creature comforts get an R33 its the biggest whale... i mean car as far as 2 door under 1.3tonne imports go. :D
the bomex kits are really nice... and ya, the interior for 180s really sxxk big time.. :(:D:mad: :mad: :mad:
BTW, i found my bomex kit at a wrecker on a strawberry face silvia that was written off. Pure luck if u ask me. An original bomex will cost ya about 9grand.
You can get fibreglass copies n aus now tho for about 4k-5k, with all the ichi-go kits (strawberry faces) that come down here. I know Skyline Imports in Adelaide got one about a month before I got mine back then, I'm sure they still have the moulds.
awesome! are there many of these around? or would u have to do the conversion urself and or import one?? that sounds wicked!! im contemplating a new car but i really dont want to sell my baby.
not that i know of, dude.. there's only one in perth that i saw... which is show cased in one of the garages.. i'm not really sure how or whereabouts doing the conversion itself.. but i do know there are people over at japan doing conversions for ichigoes =P
its actually a kit that was made by bomex, but not sold commercially in mass quantities, to keep its uniqueness.
Its basically the next version of the "sileighty" look.
The panels all fit a 180/silvia very snugly... all you need to do is chop a lil bit of the front bar support off (with your friendly angle grinder) and the rest bolts into place.
In the kit you get:
2 front guards that sit on the 180 chassis and flow into the existing doors and a pillar shape.
2 original s15 headlights
1 fibreglass bonnet also in the s15 shape but with a lil bit of bracket and mounting work under to fit the 180 chassis.
The front bar actually comes seperate, but you can source it from them if you want.
i got pics for the install process if u guys want
my local panel beater fixed up the dents in my kit and installed it on my 180 for me. Mine was like the 7th in australia or sumfin. God knows how many there are now with couple of the shops making fibreglass moulds of the original bomex kit.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
