Wanna know a funny fact?.. The best over all flow and filter reading came from a cheapo one..
Off the top of my head I remeber it to be the cheapo one.. I could be incorrect.. But I definately remeber 1st or 2nd was the cheapo one..
Ill gladly change and take back mywords if Im worng :rofl:
Between getting that TINY bit of better flow and or filtration.. and saving $150.. Id take the cheapo one..
When Im home in 2 weeks Ill re-hash this and publish the findings.. I remeber they did it quite proffessionaly on a flow table with filtration..
  • Replies 94
Posted Images
How do u rekon a HKS Pod would do???????
suction wise
yeaha a hks pod i know for sure do have a lot of suction noise on them i have heard it on a new skylines, however not to sure on the filtration quality, however i can replace the filter on them easy, off ebay.
hame :sorcerer:
HKS suck loud.. but they suck for filtration wouldnt be such a problem for N.a tho..
A metal pipe will increase the sucktion noise as it resonates the sound. abit pricy tho ;)
get apexi sound cool :O and good filtering.. check the for sale section.. someone has a bling chrome one for sale and a normal one too :(
sorry for repeating myself but do you guys honestly get suction noise on your non turbos because i got a K and N and its not making any noise i just assumed cause its non-turbo but after reading this and your all getting noise,, maybe mines not mounted proberly or something
anyway turbo 33 in 2 weeks lol but still id like to know why mines got NO suction noise
it doesnt sound good cos its an NA.
it sucks, but not in the way you want it to. :D
Just remembered you can buy a "suction kit" for our cars which replaces the rubber pipe. Increase noise quite abit
Suction kit... hmm where would i get my hands on one of them???
Does it come wif a HKS Pod?
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
