What condition is it in?
Why are u selling it, to replace it with a stock one?
How many km's has it done?
When selling something please give as much detail as possible (including price) so people can make an informed decision.
PS: I'm not interested in buying it myself, just thought i will ask the obvious questions to help everyone else.
the diff is currently in my car as i said , and its in excellent order. The reason why i havent put a price on this item is because i dont know how much its worth, but i was told by a couple of people that it is worth a fair bit.
please give me a call if you're interested on 46531575 or 0404810421 ask for matthew
Originally posted by ma160802
what are you offering?
$100 and a spin around the track in my car once it's installed.
As Blitz said , post a price , this is not a dutch auction.
Cheers
Ken
I'd suggest you do your research before randomly advertising your goods for sale.
There are many types of NISMO LSDs available.
Two main types are: SSS LSD, and Mechanical LSD.
SSS LSD has two different types available for BNR32 and BCNR33:
2 Way LSD - 38420-RS205-E
1.5 Way LSD - 38420-RS207-E
Both are 105,000 Yen.
The NISMO Mechanical LSD, there are 4 types available for GTR:
R200 LSD - BNR32 Start ~ 93/02 - 4.111 Ratio - 38420-RS500A
R200 LSD - BNR32 93/02 ~ End - 4.111 Ratio - 38420-RS581A
R200 LSD - BCNR33 - 4.111 Ratio - 38420-RS581A
R200 LSD - BNR34 - 3.545 Ratio - 38420-RS581A
All are 86,000 Yen.
WHICH ONE DO YOU HAVE?
The bill for my time is in the mail. Prompt payment is appreciated.
Merli
ma160802 should be able to afford quite a bit for the info... judging by what he wants for the diff... LOL Seriously ma160802, we are buying close to 80yen at the moment, and consiquently parts are cheap from Nippon. Think your $AUD1300 is a bit steep.
I have a standard "out of R32" clutch type centre in extremely good condition you can have for $AUD500.00 FOB. Don't want your AM one though
Ciao
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
