Item: Endless/Zeal "Super Function" coilovers
Age: 8000km
Condition: Very good
Price: $1100 ono PRICE DROP - $1000 (these are over $4,000 new)
To Fit: R33/R34 GTR
Contact: [email protected]
Comments: Top of the line circuit suspension :laugh:
Item: 5R Racing intercooler 600x300x113. No pipes. Big bad boy alloy intercooler, 3" inlet/outlet.
Condition: brand new.
Price: $350 ono
To Fit: R33/R34 GTR, any car really just need to make piping
Comments: For big power, drag car, etc. Selling as I'm no longer going to use this.
Item: RB25 Clear Cam/Timing Belt Cover
Age: New, never fitted
Price: $120 FIRM.
To Fit: R33 GTS-t. R34 GTT with some spacers
Comments: Bought in group buy, apparently doesn't perfectly fit R34 NEO engines
Item: HKS Type-S intercooler including piping
Condition: Average, Used
Price: $750 ono ** SOLD **
To Fit: R33 GTST or R34 GTT
Comments:
Item: Nismo S-tune coilovers for R34 GTT (should also fit R33/R34 GTR)
Condition: Good Used condition, all working when removed from car
Price: $950 ono
To Fit: R34 GTT, R33/R34 GTR.
Comments: Great smooth handling for street, not too harsh, Height & Damper adjustable
Item: C-West FULL Carbon Fibre Bonnet for R34 GTT
Age: 2 years
Price: $1100 (Genuine RRP, $2400)
To Fit: R34 GTT
Comments: couple of minor stone chips. Not some cheap fibreglass with single layer carbon, this is a quality Japanese made full Carbon bonnet.
  • Replies 50
Posted Images
how much would you charge me for shipping to sydney 2070 the c-west carbon bonnet?
can i get some detailed picture (close up) of it through to my email?
such as at the each corner under neath the boneet, vented area and front bit.
my email is [email protected]
thanks
paul
Edited by tyaos
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
