Hey all,
Just last night this has happened and has continued on this moring. when i put the indicator on turing right it does the normal slow flashing... But when i turn it on to the left it flashes on and off reali fast..
Then some times its ok then does it again...
any ideas how to fix ??
https://www.sau.com.au/forums/topic/193737-indicators/
maybe a connection in one of your indicators. flashing really fast generally means one is blow or more likley in your case has a bad contact somewhere near the bulb. when its flashing really fast jump out and check your indicators. when its flashing really fast you will probably find one of your front side or rears isnt flashing.
just the first thing to check
https://www.sau.com.au/forums/topic/193737-indicators/#findComment-3475572
ahhh cheers of course ill check it out! thanks
https://www.sau.com.au/forums/topic/193737-indicators/#findComment-3475596
(sorta) off topic question:
are the parker lights in any way affiliated with the circuit of the indicators?
i had this problem for a couple months, and it busted the indicator globes a couple times. i had a set of led parkers and as soon as i took them out everything went back to normal.
https://www.sau.com.au/forums/topic/193737-indicators/#findComment-3477659
Not sure man. An hour or two following trace lines in the workshop manual would hold your A: though...
https://www.sau.com.au/forums/topic/193737-indicators/#findComment-3484292
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
