Fixed Speed Cameras
The Dan
 Share
  • Replies 95
Posted Images
Some interesting points from Bill Tuckey.
Try read it with an open mind and some patience as it is long, but this is the message that needs to get out to convince people that staying under the speed and .05 limit will not guarantee your safety on the roads.
It's time the government stopped making revenue from speed.
http://www.theaustralian.news.com.au/story...5010800,00.html
Emphasis in all Australian states has shifted from surveillance and visual deterrence to speed measurement, as if this is the main crash factor apart from alcohol.
The overemphasis on speed as a factor justifies government investment in ever more sophisticated technology to trap more vehicle users; in fact, government polling shows this gives voters a nice warm feeling because the authorities are seen to be doing something. Thus, as mobile road patrols vanish, we are losing the ability to check on the use of phones, suspended licences, outstanding warrants, underage drivers, the wearing of seat restraints, lane discipline, tailgating, unroadworthy vehicles and the rest.
No longer do police sit and watch for those rolling through stop signs, as they did in the 1970s, nor can they lurk at railway level crossings to stop the growing incidence of vehicle-train crashes. They can't. They simply don't have the manpower, or are diverted to more revenue-worthy pursuits.
Thanks for that Geoff.
and pulling all the bombs off the road...
Went past a 40/45 series land cruiser this morning on the way to the shops to get milk and it was so full of rust if he had hit a pole it would fall apart...
I could see the pedals/feet through a rust hole in the door at the lights...
Man i agree with that Australian article, it's all about public perception to what causes fatal crashes and not actual facts. Same as the whole every import driver is a hoon perception and that hoon's cause fatal crashes....
  • 3 weeks later...
Tarragindi off-ramp (M1) on Brisbane's Southside
wow, they're going to get a shitload of tickets out of this one
Saw the camera busy flashing yesterday (targeting car towards city).. i guess not many people realize there was a camera installed in between highway.
Also spotted some lines on Kingsford smith drive somewhere near Harvey st (Eagle Farm) ..? can't see the nice little box tho.. :D:D Anyone seen this ?
  • 3 weeks later...
As far as I can tell it is about where the red circle is in the map, on the Hwy there is a gap where the popo used to sit with their radar trap.
That's the one that i saw few weeks ago busy flashing.. so i guess it just started to operate now.. :thumbsup:
 Share
    • I want someone to make side skirt extensions. But by 'extensions' I mean running from one side of the car to the other, forming a flat undertray, maybe one that runs to the front and rear of the car too
    • Meh, maybe the JSAI ones are FG not CF. But, given that I'm not convinced any of these look any good, it hardly matters.
    • Got them in the other day. I can confirm the r33/r34 nozzles (B8K30-AA000) are the exact same. Hope this helps anyone else that comes looking for it
    • Yeah, I should state I have no overheating issues except when it's sitting idle, with AC on (and only then) and only on VERY VERY hot days. And it stops if I turn the AC off. But I put a lot of effort into making this thing run like a regular car, I want the AC to work when I want it to work. I need no excuses as to why I should make some other thing a daily! And tbf, the thing does heat soak pretty bad, not much I can do with the exhaust running under the driver's seat, you can feel it through your shoes/pants when you step out of the car, too. Point being, aircon inside the cabin is on pretty frequently. I did think about removing heater hoses to simplify the engine bay/back of engine because I cannot imagine a scenario where I ever need a heater. Except for defogging, but doesn't AC do that, not the heater? So in this very limited situation, raising the rear could work, purely to let hot air out. I've ran the car at the track on a 35C day with the aircon on, and it doesn't overheat in that scenario so that's why I thought it was due to heat soak/heat buildup and not just general overheating under load. I had previously tried shrouding the radiator, changing my balancer to a non-underdriven one to spin the water pump more at idle too, and installing two more thermo fans on the other side of the radiator/AC condenser. (So I have 4 now, 2 pushing, 2 pulling from the rad) neither really helped in this very limited scenario. I don't know if the vents will, but visually seeing the heat steaming out of them did give me hope, not to mention the temperature of the vents was MUCH hotter than other areas of the bonnet. Enough that one of the paint guys was unsure as to whether paint would stick to it long term. I'm sure that will be fine also.
    • JustJap sell CF underskirts like that.
