  • Replies 95
Posted Images
Some interesting points from Bill Tuckey.
Try read it with an open mind and some patience as it is long, but this is the message that needs to get out to convince people that staying under the speed and .05 limit will not guarantee your safety on the roads.
It's time the government stopped making revenue from speed.
http://www.theaustralian.news.com.au/story...5010800,00.html
Emphasis in all Australian states has shifted from surveillance and visual deterrence to speed measurement, as if this is the main crash factor apart from alcohol.
The overemphasis on speed as a factor justifies government investment in ever more sophisticated technology to trap more vehicle users; in fact, government polling shows this gives voters a nice warm feeling because the authorities are seen to be doing something. Thus, as mobile road patrols vanish, we are losing the ability to check on the use of phones, suspended licences, outstanding warrants, underage drivers, the wearing of seat restraints, lane discipline, tailgating, unroadworthy vehicles and the rest.
No longer do police sit and watch for those rolling through stop signs, as they did in the 1970s, nor can they lurk at railway level crossings to stop the growing incidence of vehicle-train crashes. They can't. They simply don't have the manpower, or are diverted to more revenue-worthy pursuits.
Thanks for that Geoff.
and pulling all the bombs off the road...
Went past a 40/45 series land cruiser this morning on the way to the shops to get milk and it was so full of rust if he had hit a pole it would fall apart...
I could see the pedals/feet through a rust hole in the door at the lights...
Man i agree with that Australian article, it's all about public perception to what causes fatal crashes and not actual facts. Same as the whole every import driver is a hoon perception and that hoon's cause fatal crashes....
  • 3 weeks later...
Tarragindi off-ramp (M1) on Brisbane's Southside
wow, they're going to get a shitload of tickets out of this one
Saw the camera busy flashing yesterday (targeting car towards city).. i guess not many people realize there was a camera installed in between highway.
Also spotted some lines on Kingsford smith drive somewhere near Harvey st (Eagle Farm) ..? can't see the nice little box tho.. :D:D Anyone seen this ?
  • 3 weeks later...
As far as I can tell it is about where the red circle is in the map, on the Hwy there is a gap where the popo used to sit with their radar trap.
That's the one that i saw few weeks ago busy flashing.. so i guess it just started to operate now.. :thumbsup:
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
