Hi,
Thought I’d put the word out… Please pass it on if you know of anyone this might be relevant to.
There is a Black r32 in good condition dumped/stolen/neglected on the southside of Brisbane. (will not mention where exactly) Around the Greenslopes/Annerley area. The registration plates have been removed as well as the sticker. It has 16/17” silver rims, a stock exhaust, tinted windows. I will provide pictures tonight when I get home from work.
I originally thought the car could have been turbo with a black painted intercooler though I might be mistaken. It looks very stock and possibly de-badged. The rear window tint is bubbling.
If you have lost or recently had your r32 stolen, please reply to this thread and I will contact you with details. It has been there for 2 days now.
Thanks,
Zachary.
J-Spec 300zx Twin Turbo @ 245rwkw, Stock Internals – $$$Zees Exhaust$$$ :-D
A call to the local police would probably be more useful.
they'd have all reported thefts to match up with.
or would be within their rights to pop the bonnet to get the chassis number, get it matched at QLD transport and call the owner.
just my 2 Lira
just my 2 Lira
Fantastic. I would have never thought to do that hey?....
Real deep...
Cheers for hijacking the thread, appreciate it heaps fellers.
Its a R32 GTR, imported off the boat and probably stolen. So if some poor guy is waiting for their import to be complianced then I know where it is. The car has NOT been registered yet, so the police are going to find it hard to get the owner since there techniqicly isnt one as there is no documentation on the transport databases.
It has DUNLOP semi slicks on all 4s, no child restraint harnesses. My friend that imported his r34 was with me so he knew the deal. All import stickers still intact.
Anyones?
Zac
J-Spec 300zx TT, 245rwkw - $$$Zees Mufflers$$$
Our mission was pretty funny though... So many rednecks, so little education. Lawl at trying to bribe the fools to get the car out.
True, was a bit of an effort though, and wasnt danny from add impressed rolf
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
