Hi all
I have a R34 GTT with the following suspension mods:
- tein super streets
- whiteline front (24mm) and rear sway (20mm) bar both on soft
- front and rear camber kits
- front castor kit
- aligned to SKs settings, pretty much everything is SK spec except coilovers and slightly smaller rear bar
Problem I am having is that when I take say a hard left corner, the rear seems to hop hop hop as if the rear passenger wheel is coming up and off and onto the road again. Its either that or the tyres are rolling on the side so much that Im getting that feeling. it is hard to explain but its like the rear of the car is hopping along to follow the cornering line.
The front seems fine to me and is well planted.
Any ideas what it could be? or what I should try to get rid of it? is it too much body roll?
Thanks
https://www.sau.com.au/forums/topic/193750-rear-seems-to-hop-on-hard-cornering/
does the car actually kind of buck? called pig rooting? happens in slower, tighter corners. and it happens when you are getting on the power just before the apex?
Dont quite get what you mean by bucking BB? But im def. not getting on the power early
like as in the car is behaving as though it was a mechanical bull. ie jerking up and down as you are cornering?
I get that, but only on the street. I know my rear springs are too hard, but is there another reason it happens?
I seemed to have that problem at one stage :) my cars left hand rear shock had gone simple bounce test later and a replacement found and its been all good so far
it bounced around on tight corners but also on long sweeping corners at speed :) however it may have no relevance as i have a 33 but still thats my 2 cents hope it helps :)
Edited by SeanO
Were the Teins new?
You keep having weird problems with this car eh.
Are you slowing or accelerating through 80km/h during this corner?
Have you got a new bike yet?
Hahaha i dont really have any problems at all, i always think i do but its always fine in the end, i think its just my fussy self hahah
i think ive been pretty lucky to have everything go well with the car so far (knocks on wood)
teins are new, 1 year old, only done maybe 10 thousand km on them
its like a tight bend, im only doing maybe 50km/hr, maybe its just the nature of the bend, its one of those ones that get tighter as you get into it
naah still trying to sell the white cibby first, then onto a 600cc hopefully
i have exactly the same problem too. Theres a nasty winding road when i got to Bendigo its like a U turn on the middle of the hill and each time i turn it seems the tyres are slipping at the rears. Sort of felt like going into a dip and the car bounce back. I installed the tein read my signiture for specs.
Sounds like, insufficient rebound damping in the shocks to control the spring wind up caused by the rear squat on acceleration. Typical of a poorly matched spring rate and shock valving.
If you have adjustable shocks, try winding them up towards full stiffness. It sometimes helps.
Cheers
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
