Hi all
I have a R34 GTT with the following suspension mods:
- tein super streets
- whiteline front (24mm) and rear sway (20mm) bar both on soft
- front and rear camber kits
- front castor kit
- aligned to SKs settings, pretty much everything is SK spec except coilovers and slightly smaller rear bar
Problem I am having is that when I take say a hard left corner, the rear seems to hop hop hop as if the rear passenger wheel is coming up and off and onto the road again. Its either that or the tyres are rolling on the side so much that Im getting that feeling. it is hard to explain but its like the rear of the car is hopping along to follow the cornering line.
The front seems fine to me and is well planted.
Any ideas what it could be? or what I should try to get rid of it? is it too much body roll?
Thanks
My car will also do this under specific conditions.
I have one particular corner near home - the street is very steep and the corner is at the apex of the hill.
Take that corner tight enough & above a certain speed and the inside wheel lifts momentarily.
Not a big problem for me, but just thought I'd mention it.
I'm running Nismo coilovers and whilst I'm no expert I'm guessing its just a small tradeoff I have to make, as the suspension is otherwise great under most other conditions (Can't say the same for the tyres in the wet though!).
Cheers,
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
