Hey guys, just abit puzzled on what the VCT thing is, been searching around but havn't quite found my answer.
just wanna know what is VCT and what it does and how do you tell if you have it?,
i read sumwere all rb25de motors has VCT except an rb25de from r32, is this correct?
https://www.sau.com.au/forums/topic/193759-vct/
it's called NVCS, the inlet cam is advnaced 20º when the solenoid is on.
you can see a solenoid on the intake side, red plug from memory. you can also feel it kick when when the solenoid is activated.
r32 rb25de = NO NVCS = correct
put the keywords NVCS or VCT on the search engine for the entire forum, should bring up lots of hits.
https://www.sau.com.au/forums/topic/193759-vct/#findComment-3476242
here ya go:\
NVCS is the acronym for Nissan Variable cam system, it is found in the RB25DE, RB25DET and the RB25DET NEO. NVCS is not to be confused with Hondas V-TECH system which alters lift and duration high in the rev range to give higher peak power. Nissans system uses cam phasing to increase low to mid end engine torque.
Optimal valve opening and closure position for a given duration is different for every RPM and load combination, NCVS gives the engine the ability to take these factors into consideration and alters the timing accordingly. This is done using an electronic solenoid which adjusts the rotation of the cam by a maximum of 20 degrees, the solenoid is controlled by the engines ECU.
The RB25DE and RB25DET found in the R33 Nissan skyline only use the NVCS system on the intake Cam. The R34 Nissan Skyline is equipped with the NEO version of this engine and both intake and exhaust cams use the NVCS system. The RB20DET and RB26DETT do not use NVCS.
Torque curve of a VG30DETT with NVCS off and on notice the low to mid torque increase with the system turned on.
NVCS makes a considerable difference to low and mid range torque so when it comes to upgrading cams or installing cam gears it is a good idea to keep this system in place. Some manufactures (like tomei's poncam range) make cams to work with NVCS I highly recommend you consider these. As the non NEO RB25's only have NVCS on intake side an exhaust cam gear can be used as a good cheap upgrade to improve mid to high end torque.
https://www.sau.com.au/forums/topic/193759-vct/#findComment-3476534
o ok, that was very helpful, thanks guys, 1 more thing, ive heard alot of ppl tell me an rb25de is 140kw@flywheel and 147kw@flywheel WITH VCT / NVCS and only the rb25de from an r32 is without VCT / NVCS. So does this mean that ALL N/A r33s come equipped with VCT / NVCS? i.e, 147kW? i got a s2 33gts4 lol
https://www.sau.com.au/forums/topic/193759-vct/#findComment-3476942
they r33 type-s has 147kw fly, no idea where they got that number from though.
the non type-s also has nvcs, so the extra power is not due to that.
7kw is really nothing anyway. you can make or lose 7kw by running the dyno on different days, different fuel, condition of the motor, dyno settings, etc.
all r33s that came with rb25s have nvcs
some r33s came with an rb20e, they do not.
you should have nvcs in an s2 r33 gts4
https://www.sau.com.au/forums/topic/193759-vct/#findComment-3477005
But because its a GTS4 you will loose a certain percentage through the 4WD system..
https://www.sau.com.au/forums/topic/193759-vct/#findComment-3477105
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
