Hi there is a similar topic i found to this but it was for an RB25DET :wave:
Just want to know....
what are the gains on adjustable cam gears on a RB20DET 32?
Get the timing belt done as im approaching the 150, 000km mark and the 'Mechanic' advised it needs to be done. (might get a second opinion lol)
so have a few kits i am looking at (with or without the adjustable cams) not sure which way to go?
any help would be appreciated heaps :)
Edited by DaShMiEsTeR
https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/
Peak power might only rise a couple of kilowatts if it does...adjustment of the cam gears might allow you to shift your powerband around slightly...alot of people recon its abit of a hit or miss with cam gears but it can't hurt to try...
Edited by limpus
cheers mate. still sort of borderline on whether or not to get it done. But if its a hit and miss i might give it a shot.
Probaly only minimal gains with standard cams, but still a gain.
Have you thought about aftermarket cams.
sorry thats what i was going to do. Get some aftermarket adjustable cams.
so you think either way the cams will provide a gain?
I think it all comes down to the experience of the tuner and whether you are willing to pay for all the dyno tiume whilst the settings are changed and the ignition anf fuelling gets tweaked so that you actually get a tangible change in power/delivery.
Im still waiting to see a credible before and after comparison of an RB20 with some cams. Same tuner, same bolt on and support mods, only change is cams a tweak of the tune to suit.
Hopefully this wednesday i will be adding Adj cam gears and getting another tune on the same dyno, same tuner and with the same mods (except for the Adj cam gears), ill keep people posted as it will be interesting to see what difference they make and at what settings on a Std cam stock internal RB20. Here is the Dyno sheet from my last tune on ~15 psi
keep everyone posted dude
that will be an interesting outcome :D
I will be dropping the cams in my motor so hopefully will see a bit of a difference through the midrange from the 200rwks it began with.
Will post up results of before and after graphs in the RB20 thread once done :)
Will post up results of before and after graphs in the RB20 thread once done :thumbsup:
awesome! :thumbsup:
you probably won[t gain any top end but it will bring boost on sooner and shift your power curve left
this means power is available earlier across the whole rev range
...very worth it on the rb20 which we all know lacks balls below 3000rpm
haven changed cam gears on my rb20 with rb25 turbo (i made a thread about it - do a search), i say go for it!
Going slightly larger than 256 though and looking for the increase through midrange and to help bring on boost earlier :thumbsup:
alright cool
that would cool
evenly spread sounds like what i want
not more power but maybe an even spread of power especially before 3000rpm would be awesome haha
thanks man :thumbsup:
  • 2 months later...
So what happened with this retune with the adju cam gears? any new dyno graphs you care to share with us :P
About the timing belt....i thought it was meant to be done at 100,000kms as well........
I would be doing it fairly quickly if you are reaching 150,000kms.
As well as you idlers and tensioners....
Edited by Douse
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
