DaShMiEsTeR Posted November 15, 2007 Share Posted November 15, 2007 (edited) Hi there is a similar topic i found to this but it was for an RB25DET Just want to know.... what are the gains on adjustable cam gears on a RB20DET 32? Get the timing belt done as im approaching the 150, 000km mark and the 'Mechanic' advised it needs to be done. (might get a second opinion lol) so have a few kits i am looking at (with or without the adjustable cams) not sure which way to go? any help would be appreciated heaps Edited November 15, 2007 by DaShMiEsTeR Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/ Share on other sites More sharing options...
limpus Posted November 16, 2007 Share Posted November 16, 2007 (edited) Peak power might only rise a couple of kilowatts if it does...adjustment of the cam gears might allow you to shift your powerband around slightly...alot of people recon its abit of a hit or miss with cam gears but it can't hurt to try... Edited November 16, 2007 by limpus Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3478626 Share on other sites More sharing options...
DaShMiEsTeR Posted November 16, 2007 Author Share Posted November 16, 2007 Peak power might only rise a couple of kilowatts if it does...adjustment of the cam gears might allow you to shift your powerband around slightly...alot of people recon its abit of a hit or miss with cam gears but it can't hurt to try... cheers mate. still sort of borderline on whether or not to get it done. But if its a hit and miss i might give it a shot. Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3479608 Share on other sites More sharing options...
r32sky_line Posted November 16, 2007 Share Posted November 16, 2007 Probaly only minimal gains with standard cams, but still a gain. Have you thought about aftermarket cams. Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3479920 Share on other sites More sharing options...
DaShMiEsTeR Posted November 18, 2007 Author Share Posted November 18, 2007 Probaly only minimal gains with standard cams, but still a gain.Have you thought about aftermarket cams. sorry thats what i was going to do. Get some aftermarket adjustable cams. so you think either way the cams will provide a gain? Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3482932 Share on other sites More sharing options...
battery Posted November 18, 2007 Share Posted November 18, 2007 Get the timing belt done as im approaching the 150, 000km mark and the 'Mechanic' advised it needs to be done. (might get a second opinion lol) i always thought that the timing belt was done every 100,000km? Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3483005 Share on other sites More sharing options...
Roy Posted November 19, 2007 Share Posted November 19, 2007 Probaly only minimal gains with standard cams, but still a gain.Have you thought about aftermarket cams. I think it all comes down to the experience of the tuner and whether you are willing to pay for all the dyno tiume whilst the settings are changed and the ignition anf fuelling gets tweaked so that you actually get a tangible change in power/delivery. Im still waiting to see a credible before and after comparison of an RB20 with some cams. Same tuner, same bolt on and support mods, only change is cams a tweak of the tune to suit. Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3483283 Share on other sites More sharing options...
DaShMiEsTeR Posted November 19, 2007 Author Share Posted November 19, 2007 so its completely dependent on the tuner? Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3483352 Share on other sites More sharing options...
Ceffy_SA Posted November 19, 2007 Share Posted November 19, 2007 I think it all comes down to the experience of the tuner and whether you are willing to pay for all the dyno tiume whilst the settings are changed and the ignition anf fuelling gets tweaked so that you actually get a tangible change in power/delivery.Im still waiting to see a credible before and after comparison of an RB20 with some cams. Same tuner, same bolt on and support mods, only change is cams a tweak of the tune to suit. Hopefully this wednesday i will be adding Adj cam gears and getting another tune on the same dyno, same tuner and with the same mods (except for the Adj cam gears), ill keep people posted as it will be interesting to see what difference they make and at what settings on a Std cam stock internal RB20. Here is the Dyno sheet from my last tune on ~15 psi Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3483366 Share on other sites More sharing options...
DaShMiEsTeR Posted November 19, 2007 Author Share Posted November 19, 2007 Hopefully this wednesday i will be adding Adj cam gears and getting another tune on the same dyno, same tuner and with the same mods (except for the Adj cam gears), ill keep people posted as it will be interesting to see what difference they make and at what settings on a Std cam stock internal RB20. Here is the Dyno sheet from my last tune on ~15 psi keep everyone posted dude that will be an interesting outcome Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3483420 Share on other sites More sharing options...
-_-StRyDeR-_- Posted November 19, 2007 Share Posted November 19, 2007 Also very interested in this!! CJ Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3483439 Share on other sites More sharing options...
grandmasterb Posted November 20, 2007 Share Posted November 20, 2007 I will be dropping the cams in my motor so hopefully will see a bit of a difference through the midrange from the 200rwks it began with. Will post up results of before and after graphs in the RB20 thread once done Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3485585 Share on other sites More sharing options...
DaShMiEsTeR Posted November 20, 2007 Author Share Posted November 20, 2007 I will be dropping the cams in my motor so hopefully will see a bit of a difference through the midrange from the 200rwks it began with.Will post up results of before and after graphs in the RB20 thread once done awesome! Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3485610 Share on other sites More sharing options...
WazR32GTSt Posted November 20, 2007 Share Posted November 20, 2007 you probably won[t gain any top end but it will bring boost on sooner and shift your power curve left this means power is available earlier across the whole rev range ...very worth it on the rb20 which we all know lacks balls below 3000rpm haven changed cam gears on my rb20 with rb25 turbo (i made a thread about it - do a search), i say go for it! Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3485991 Share on other sites More sharing options...
grandmasterb Posted November 20, 2007 Share Posted November 20, 2007 you probably won[t gain any top end but it will bring boost on sooner and shift your power curve leftthis means power is available earlier across the whole rev range ...very worth it on the rb20 which we all know lacks balls below 3000rpm haven changed cam gears on my rb20 with rb25 turbo (i made a thread about it - do a search), i say go for it! Going slightly larger than 256 though and looking for the increase through midrange and to help bring on boost earlier Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3485999 Share on other sites More sharing options...
DaShMiEsTeR Posted November 20, 2007 Author Share Posted November 20, 2007 you probably won[t gain any top end but it will bring boost on sooner and shift your power curve leftthis means power is available earlier across the whole rev range ...very worth it on the rb20 which we all know lacks balls below 3000rpm haven changed cam gears on my rb20 with rb25 turbo (i made a thread about it - do a search), i say go for it! alright cool that would cool evenly spread sounds like what i want not more power but maybe an even spread of power especially before 3000rpm would be awesome haha thanks man Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3486001 Share on other sites More sharing options...
hitoriko Posted November 23, 2007 Share Posted November 23, 2007 and what happened to your dyno run? Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3494304 Share on other sites More sharing options...
GTshortie Posted February 12, 2008 Share Posted February 12, 2008 Hopefully this wednesday i will be adding Adj cam gears and getting another tune on the same dyno, same tuner and with the same mods (except for the Adj cam gears), ill keep people posted as it will be interesting to see what difference they make and at what settings on a Std cam stock internal RB20. Here is the Dyno sheet from my last tune on ~15 psi So what happened with this retune with the adju cam gears? any new dyno graphs you care to share with us Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3639933 Share on other sites More sharing options...
Douse Posted February 12, 2008 Share Posted February 12, 2008 (edited) About the timing belt....i thought it was meant to be done at 100,000kms as well........ I would be doing it fairly quickly if you are reaching 150,000kms. As well as you idlers and tensioners.... Edited February 12, 2008 by Douse Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3640055 Share on other sites More sharing options...
47une Posted February 12, 2008 Share Posted February 12, 2008 Well done for bringing this one back up GTShortie, I am very keen to know the difference too. Link to comment https://www.sau.com.au/forums/topic/193794-rb20det-adjustable-cams/#findComment-3640380 Share on other sites More sharing options...
