Hey
Just preparing my front bar to be repainted, just had a few quick questions in regards to what grade sandpaper to use to prepare the bar.
The front bar has already painted with a clear coat etc, just wanted to know what would be the best grades of paper sandpaper to use to get it ready to repaint.
I want a really good finish, so if someone could write up the procedure with the grades of paper that would be good.
Dry/wet sand, paper grade etc etc
Thanks,
Abu
Edited by abu
Im not a professional but i have sprayed a few parts and what not in the past.
If the bar currently has good paint and clear coat you could use a 800 wet/dry paper the remove the clear coat or at least create a surface for the primer to grab. Anything courser will leave marks from sanding.
After sanding clean of the dust and oil from hands etc. with prep sol, spray it with a 1k primer "high Fill" that should fill small cracks and sanding marks. Lightly rub any inconsistency back with a dry yellow paper "240 three cut" very light sand all over so it dosnt leave more marks. Clean with prep sol
spray again with 1k primer, you should now have a flawless finish, if you have messed up any of the last coat of primer repeat sanding with the 240. Now it should be ready for you colour coat.
Let the colour coat "flash off" dry for about 10 minutes in between coats, depending on colour it might take 4 coats. Once you have a solid colour coat, let it fully harden over night, then sand with 800 wet paper to remove and texture from spraying and dust, clean with prep sol and spray final coat of colour. Let it dry fully before the clear coats especially if it’s a metallic colour. Clean with prep sol;
Now lay down some clear coats ie 3, again once you are happy let it full dry. Give it a wet sand with 800, clean with prep sol and spray the final clear coat.
This should leave you with one hell of a good final finish; the trick is during any of the process if your not happy with something do it again. Hope it helps
Thanks for the replies guys.
Bar has been repaired as it was cracked, but is a good finish. The section that was repaired is in primer, and the rest of the bar still has the origin paint on it.
The rest of the bar has slight fracture marks as the bar flexed a fair bit when it was damaged.
Will the whole thing require undercoat, or can I take the clear off and paint over it?
Edited by abu
Yeah cracks are all gone..
Anyways sanded it all back earlier tonight, doing the undercoated tomorrow morning, then will wet/dry sand the undercoat and finish it off with some 2pac and clear.
Will see how it goes tomorrow.
Thanks for the help.
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
