  • Replies 100
Anyone with xbox 360 wants any blueprints for the many cars i have, send me a friend request and ill send you every blueprint i have. My gt is: OZ aus
I havent done speed king yet and probably wont bother but im king in everything else.
damn this game looks sweet as!
Will it run on med/high graphics on a AMDx2 6000+, 2 gig 800mhz ram and a 7600GT card?
I am going to buy it tonight if yes, am sick of buying games and them not running well heh
mm downloaded it and on 800X600 with most graphics options at low it runs terrible at around 10 frames per second..
Bit crap how u can't go through the streets or free roam any, not a fan of track games, the best NFS game is still high pursuit imo..
Also very crappy controls, impossible to play with keyboard and after like 15 minutes configuring my control it still felt retarded and turned too sharp
played it on ps2, what a joke. what the f*ck is up with the drifting, you go round 5 corners per track? wtf?? the zonda was so skittish on the speed mode i sold it and got a 911 turbo, much more stable. thought it was a bit odd that i could only squeeze 680bhp out of the r35.
i had to adjust the audio so i could stop hearing about ryan cooper blah blah blah
nfs most wanted was heaps more fun.
dunno if shes in the game but i know she promo`ed it
yeh shes in it, shes the chick that most of the time starts the race, gives the camera a wink etc... kinda looks like her... doesnt really make the game better, which isnt to say that i dont like the game
eeeh.. kinda stuck.
how do you do wheeelieees lol?
i got a 800hp 34 for drag n shit n it aint working !!!
might want to consider a RWD car for wheelies.
Anyone got the damn patch and 'booster pack' to work? As soon as I install it the game no longer starts, gets to the loading bit and then crashes which is very frustrating. Have to uninstall, delete the folder and reinstal to get v1 to work again.
  • 2 months later...
Guest trikdoutvl
this game was so dissapointing i had a day off work to buy and play this game LOL... was like seeing a child born opening the packet n then dropping the disk in the xbox360....... then played it and was so dissapointed its not funny. the game is poo especially the drifting its fooking crap.. try n do a doughnut n ur car turns into a 5hp understeering bucket of crap... ... the best part of the game is the warm up burnouts before u do a drag, looks awsome other then that game sucks ballz IMO id recogmend buying forza 2 or juiced 2 over pro street
forza 2 is only on xbox :spam: silly microsoft noobs :D
juiced 2 is rubbish.. i have it :|
"awaits till mod chip comes out to play xbox360 games on ps3" :thanks:
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
