  • Replies 100
Anyone with xbox 360 wants any blueprints for the many cars i have, send me a friend request and ill send you every blueprint i have. My gt is: OZ aus
I havent done speed king yet and probably wont bother but im king in everything else.
damn this game looks sweet as!
Will it run on med/high graphics on a AMDx2 6000+, 2 gig 800mhz ram and a 7600GT card?
I am going to buy it tonight if yes, am sick of buying games and them not running well heh
mm downloaded it and on 800X600 with most graphics options at low it runs terrible at around 10 frames per second..
Bit crap how u can't go through the streets or free roam any, not a fan of track games, the best NFS game is still high pursuit imo..
Also very crappy controls, impossible to play with keyboard and after like 15 minutes configuring my control it still felt retarded and turned too sharp
played it on ps2, what a joke. what the f*ck is up with the drifting, you go round 5 corners per track? wtf?? the zonda was so skittish on the speed mode i sold it and got a 911 turbo, much more stable. thought it was a bit odd that i could only squeeze 680bhp out of the r35.
i had to adjust the audio so i could stop hearing about ryan cooper blah blah blah
nfs most wanted was heaps more fun.
dunno if shes in the game but i know she promo`ed it
yeh shes in it, shes the chick that most of the time starts the race, gives the camera a wink etc... kinda looks like her... doesnt really make the game better, which isnt to say that i dont like the game
eeeh.. kinda stuck.
how do you do wheeelieees lol?
i got a 800hp 34 for drag n shit n it aint working !!!
might want to consider a RWD car for wheelies.
Anyone got the damn patch and 'booster pack' to work? As soon as I install it the game no longer starts, gets to the loading bit and then crashes which is very frustrating. Have to uninstall, delete the folder and reinstal to get v1 to work again.
  • 2 months later...
Guest trikdoutvl
this game was so dissapointing i had a day off work to buy and play this game LOL... was like seeing a child born opening the packet n then dropping the disk in the xbox360....... then played it and was so dissapointed its not funny. the game is poo especially the drifting its fooking crap.. try n do a doughnut n ur car turns into a 5hp understeering bucket of crap... ... the best part of the game is the warm up burnouts before u do a drag, looks awsome other then that game sucks ballz IMO id recogmend buying forza 2 or juiced 2 over pro street
forza 2 is only on xbox :spam: silly microsoft noobs :D
juiced 2 is rubbish.. i have it :|
"awaits till mod chip comes out to play xbox360 games on ps3" :thanks:
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
