So I Bought A Copy Of This Month's Unique Cars...
...and I was interested to see how Unique Cars presented it's "Club of the Month" section as I'm now doing advertising for the WRX Club and I want to make a submission to them to consider... and wasn't I pleasantly surprised when I started flipping through this issue! (Oct 31-Nov27)!!
Reading through the index page, firstly I saw there was a great write-up on the 1994 Subaru WRX Rallye edition (yeah, its spelt right!) - featuring one of our WRX club members Daniel Boyle. I went straight away to page 126 - what an excellent read it was. I'd knew that he had offered to help out Unique Cars with the article but I had no idea it was going to be in this issue. Very pleasant surprise indeed.
As i'm flicking back and forth through the pages, I turn to page 70 and guess who's golden locks and unmistakable smile bring a smile to my own face - that's right, our very own MissJuz and the article about Juz & Brisby's adventures at Dutton 07!
It was a great read, very well written and had some great photos! Unforunatly I wasn't available to come and check it in person this year (i made scruteneering but thats it) due to work so it was nice to see an article that put together all the stories I'd heard from the SAU crew.
It's weird reading about people in a major magazine when you go "hey I know them" :D
Well done to all that competed in Dutton and congratulations for making it back in one piece!
Justine, you'll be hearing from me shortly as I really want to promote the WRX club a bit more in mainstream media :)
B-man out.
Thanks Brenton, Send me an email with your details and I'll let you know what you need to submit for club of the month! Email: [email protected]
Also if you watch the Unique Cars DVD that came with the magazine you will also see another SAU Club Member showing the world his Drifting Skills in the Ford FPV Drift 6, Adam "Handbags" Newton!
Slowly but surely we shall take over this magazine so it's filled with people we know!! *rubs hands together*
Argh damnit!!!! I searched, i really did!
But it seems i searched "Unique Cars", u ppls need to get the name right to stop me looking bad :):rofl:
See you all at the Xmas parties! And thanks Juz you shall be hearing from me shortly!
But it seems i searched "Unique Cars", u ppls need to get the name right to stop me looking bad :rofl::rofl:
lol
picture war
both pics made me laugh :)
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
