yes it is worth it, everyone on here thats had them said they gain quite a lot out of them, if you do a search all the pro and cons have been gone over a few times, and i think eug is doing another group buy at the moment too so have a look at group buy section
https://www.sau.com.au/forums/topic/193925-extractors/#findComment-3478459
hey guys, i got a r33 gts, just wondering if its worth the trouble/money toget extractors for my r33.. any suggestions?? thanks!
cheers
theres a Group buy for them now..
http://www.skylinesaustralia.com/forums/Co...rs-t192351.html
https://www.sau.com.au/forums/topic/193925-extractors/#findComment-3479739
Guest NVDGTS4
Yeh i got a 2.5" catback system coz thats all i could get . There is no such " extractors" for my type of skyline that i can buy. I've got an RB25DE GTS-4 R33 Skyline and yeh i got a good muffler and it sounds like a f**kin rice cracker at 3000rpm other wise sweet. Its like a whipper snipper rasp! . i wish it was just stock now i hate it
https://www.sau.com.au/forums/topic/193925-extractors/#findComment-3481044
And why would it not fit?..
There is not logical reason why it would not fit..
Just because you have an ATTESSA driveline does not mean you cannot buy extractors..
https://www.sau.com.au/forums/topic/193925-extractors/#findComment-3481048
rofl what!!!! didn't see that coming.
sure, ill do your dirty work ya bludgers :glare:
in all seriousness, i feel we need one every now and then and if you guys feel that i'm up for the task then sure i'll give it a shot.
p.s. - thanks for the vote of trust
https://www.sau.com.au/forums/topic/193925-extractors/#findComment-3481495
well we defonatly need someone. so how about we get greg or someone who knows who to ask, to ask if they would let someone get mod status and then start a nomination poll with anyone whos interested, thats probably the fairest way to do it,
https://www.sau.com.au/forums/topic/193925-extractors/#findComment-3481936
sure, ill do your dirty work ya bludgers :)
mmm I did some behind the scenes work too a few months back lol.. I did PM a mod recommending you to become a moderator of the N/A section to fix it up etc, instead they just fixed it up themselves, didn't do much helped for a day or two.. And then the threads were back..
EDIT: Just saw you have a moderator tag lol! If anyone here deserves it it's you mate =)
https://www.sau.com.au/forums/topic/193925-extractors/#findComment-3504271
haha thanks Nick. i find that we self moderate here quite well, but any house keeping duties that come up can be amended straight away now, if required.
i have also taken on the sau qld executive job of treasurer and secretary now.
bit of a busy period for me at the moment with the change over from the old execs, but will hopefully be able to get that 'power thread' into a sticky soon to get the ball rolling. this section of the forums has really picked up recently thanks to you guys. more and more people are starting to become aware that owning a skyline isn't necessarily about having a turbo
cheers again
https://www.sau.com.au/forums/topic/193925-extractors/#findComment-3504569
    • I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
    • It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
    • speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
    • No. All these dirty old Datsuns are shitboxes. Including the GTR.
    • Yeah well I was thinking...there is nothing that happens when you get off the throttle that should cause low oil pressure, its not like clearances suddenly change or and the relief spring would close and in any case the sensor is on the feed side....so more likely there was no oil available to pick up which means all the basic oil control stuff to: 1. keep oil out of the head (restrictors) 2. get it back out of the head when it gets there (external breathers/oil return, drilling out the block and head oil returns) 3. have more oil in the sump to pick up - larger capacity sump 4. have more oil near the pick up - baffles
