Very nice pictures.
The comp covers Insert.. Are you able to take a few more pictures of it or even possibly remove it via the grub screws on the side of the comp cover snout and then take some pics of the inlet??? ;)
Awesome pics.
Take note how HKS design their dump pipe you split dump pipe users. :(
For those using the Garrett IW housing note why HKS utilize the complete area instead of being a slack arse and simply dropping a 2" pipe in there that partially blocks when the flap opens which results in boost creep on the Garrett IW turbo's.
https://www.sau.com.au/forums/topic/194027-new-toys/#findComment-3480161
Turbine housing - The HKS is a better design, bigger flap smoother gas exit.
Comp cover - The HKS is better designed due to the comp cover insert which apparently reduces inlet turbulence.
The comp cover looks essentially identical apart from the slight difference in casting which depicts its a HKS turbo. ;)
It would be interesting to see the casting finish both inside the comp cover and turbine housing.
https://www.sau.com.au/forums/topic/194027-new-toys/#findComment-3480211
That bloody idiot postie ! Hes gone and delivered it to the wrong address ! Should of went to my place ! Its mine I tell you ! MIIIIIIIIINNNNNE !
Heh its the wrong country too aswell mate unless you live in the UK like me ;)
And it wasnt a saturday, it was delivered Friday afternoon heh. So that was about 2am your time!
oh my god. i want this turbo. how much did you pay? cheers.
Just over £1350..good price I thought and it took 3 days to get here!
https://www.sau.com.au/forums/topic/194027-new-toys/#findComment-3480215
your postman delivers on a saturday?
He does but it wasnt Saturday it was friday it came, but he does come saturdays as well!
Which bit?? Lol you will have to talk in more layman terms I am not that great on knowing what bit is what and its midnight anyway...well thats my excuse!
https://www.sau.com.au/forums/topic/194027-new-toys/#findComment-3480217
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
