This prick sell parts for our lines( second hand ), my mate bought a set of coil over for his line . After trade his stock shocks and spring in we found out that his rear pair coil over was for driff only and they were all **** so we went back and ask to return it and get our stock supspension back ( me mate paid $500 for the coil over )...
This prick reckon our stock supspension was **** and he threw it out ( there were nothing wrong with our supspension ) and now if we want to return the coil over we need to purchase a stock set off him.
So me mate had no choice but to agree and he replaced his **** coil over with a set of stock supspension for me mate.
We we pick our car up i test drove it and found out that this set was even worse than my mate old stock supspension.
So if anyone want this prick name, pm me for it because i think we don't need prick like this in our society and this prick operate his business around STH EASTERN area .:D
https://www.sau.com.au/forums/topic/19403-watch-out-for-this-crook/
  • Replies 77
That seems very dodgy.. what an asshole.. report him to the Office of Fair Trading - might not do anything, but its worth doing so he doesn't get away with it anymore.
If he has been reported b4 then his number will probably be up.
Guest terrance
when u got the coil overs, why didnt you check to see if they were what you wanted? and if, as you say, they werent, just NOT PURCHASE THEM.
honestly, i worked as a mechanic part tme during my first year of uni, and most customers had the common sense to make sure they puchased what they wanted. customers like that were great but it was the common sense deprived people's money i enjoyed taking the most. they deserved the hassles that come with being a moron.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
