you can advance timing without ecu...
my opinion, unless you plan (or have) alot of mods to back it up the ecu wont give you the gains you are probably expecting. it is still going to be an additional 10~20 maybe 30kw.
compression, port, polish, cam shafts, cam gears, intake work, extractors, will net you a sweet figure.
remember the basic formula for power = air + fuel. remember in an NA system you cant just up the boost boost/air, the only way to do that is to make everything flow better, then you can add more fuel!!
i would like very much to know how to advance the timing with out the ecu!
i was always under the impression the timing was all handled by the ecu.
so an emanage or a safc2 will sort out my running very rich problems?
so i could physically rotate the crank angle sensor on the front of the engine but it would put my ignition firing out of sync?
is it worth doing the timing and ignition or would i be best to just do the air/fuel ratios?
i was thinking that for 98 octane fuel i would need a slight timing advance as the 100 octane fuel over in japan land is alot more resistant to compression etc and the timing doesnt need to be as advanced.
atleast thats my understanding of it, please correct me if im wrong.
i think you would want to retard teh timing a bit
your aim is to advance the timing as much as possible - but it is based on 100RON fuel whereas your running 98RON - so you want to retard it according to that
however - i think you can get away with a few degrees of timing advance on the crank angle sensor without knocking
have you tried an ecu reset karl??
not sure on the nissan method of resetting the ecu, but on my excel you disconnect the positive terminal when the car is still warm - leave it for about 15 min, then drain the capacitors in teh ecu by holding my foot on the brake for about 20 seconds
then reconnect the positive terminal straight away and drive the car for about 30 min so the ecu 'gets used to' your driving style
yup pretty much the same method, unplug the battery then drain the charge by holding down brake pedal for a while, then start her up and drive round in ur normal driving style be it calm or thrash whatever u do most, and let it learn agian.
I reset the ecu yesterday
went for a quick drive to get the car up to operating temperature
got home and took off the positive battery terminal
sat on the break for about a minute
through battery back in and went for a drive for about half an hour
i noticed the car does run slightly smoother now
seems a bit happier after the reset
thanks for the suggestion everyone.
  • 4 months later...
with that "how to port at home"
majority of info was there but this is whats missing
inbalance flow of all ports and/or ridiculously oversized ports can screw the power and response. always have someone with a flow bench, if not CC match the ports not as effective but can give a closer result
with the rb series motors they use more suction so with the ports the best power gains is from stopping any restrictions, enlarging reduces the sucking effect which in the end reduces power
there is no where 2 actually learn 2 port, porting is mostly trial and error and learning that while something may work with 1 type of head it may not for another
and if you do porting at home as a first time never say "its good enough" its either good or not
also im researching converting the rb25 VCT to non VCT so far I've put a bung into the face of the head, currently looking into replacing the hydrualic buckets with the solid buckets with shims or lash pads,
all i know is the lash pad kit (sits on the valve) from tomeii is like $2k and the extra length of the valve that is needed is under the bucket
where as the solid shim (sits on retainer) pretty cheap gts-r rb26 second hand but would have to replace the retainers and get longer valves
rb25 intake valves compared to rb26 intake valves, the rb26 valve head is wider, over all length is longer, valve stem same diameter
exhaust valves in the rb26 has a bigger head, longer and wider stem, looking at seeing if the rb26 exhaust guides are compatable with the rb25s exhaust guides
  • 4 weeks later...
heres my rb25de figures,as anybody got more out of a rb25de,thanks john
heres my latest dyno results,any coments please
Edited by lammy426
Lammy
This thread is about gaining performance out of a Naturally aspirated RB25. without a Turbocharger
You've put a turbo onto your car - you're using Forced Induction.. I'm sure I said that to you in another thread..
By everybody refering to their motor as an "RB25de" for example, they're meaning their car is only a "DE" not a "DET" with a turbo - Like yours.
I know you've added the Turbo after the car's production to technically it's an RB25DE+T - still a turbo.
You clearly haven't stated in the post that your car is a Turbo, Which looks to me like you're wanting everybody to "WOW!!!" "COOL MAN!" "Can we be friends??" etc.
I feel like an asshole saying this.. but stop pulling your willy please :blush:
xoxox
Lammy
I feel like an asshole saying this.. but stop pulling your willy please :P
xoxox
yes i know but months ago i put figures up when i had 350bhp and some people might be interested in what they can get out of their engines and some did show an interest even if you don't
A couple of pages back, cant be bothered finding it, it was stated that all the skyline suspension setups etc were very similar except the r34 sedan. can somebody share a bit more info on this as im planning to swap all my r33 gtst running gear into a r34 sedan. cheers
  • 1 month later...
  • 3 weeks later...
sorry if im saying somehting that has already been said
but from my knowledge there are 3 factors in increasing the power output of any engine.
these are factors of combustion
to create a fire you need 3 key elements...Fuel, oxygen, spark
so to create a bigger fire you increase any one of these
but by increasing only one element creates an unbalanced flame
to create a bigger and more efficient fire you must increase all 3 elements
therefore to increase power in an engine you must increase fuel, oxygen and spark.
fuel: bigger pump, bigger injectors, upgraded management to handle increase in fuel
oxygen: less restriction but to a certain degree. intake tract lengths can be played around with to altertorque shift and power band (read: hemi intake)
longer intake runners will create a more torqier engine, shorter intake runners will create more powerful engine.
spark: upgraded ignition eg: msd twinspark ignition system allows more timing without pinging.
great upgrade when changing the power band to encompass higher revs without sacrificing low end drivability.
the next thing to consider is response.
as previously mentioned alterations to heads, shaving, valves, valve springs, high comp lightened pistons
to get really good power out of an N/A engine you need revs or displacement.
revs: think F1. 2.8L v10? 14000rpm
lightweight pistons, short stroke rods, high compression heaps of power high in the rev range anything less than 8000rpm and it runs like shit
but when running more revs reliability decreases
displacement: one area that might not have been touched upon would be stroking. rb32de??
i know it can be done with L series engines but not sure if it would be a viable mod to rb30de.
would involve work on the internals and more specifically the crank. also dished pistons, playing around with bore and stroke.
when playing around with stroking a standard production model rb30e might not be able to be used as the bores maybe too close together.
nissan patrol rb30 block might be another option for longer stroke but not sure whether it would fit or whether it came with efi or whether it would be viable to turn into rb30de.
the r31skylineforums have debated this topic for ages and i know that someone has gone through the motions of extracting 200kw or more NA
keep in mind that the particular build in question was a no expenses spared operation.
i think i may have rambled on for too long
but hey my main point is that there are 3 key elements to extracting more power from any engine forced induction or NA
other than that the previous information is quite correct
again apologies for the long post
Its in the wrong area, its blatently turbocharged. There is nothing remarkable. There are RB30DETs based on NA RB30 bottom ends running around all over the place making >300kw @ wheels on the stock internals and you don't see any of those guys posting their NA dyno results in this thread. The reason is, they are no longer NA. Much like you.
Have people played around with decent cold air intakes, using ram air or anything?
Edited by Lithium
if i had an n/a and i wanted more power or shall we say better acceleration i would do;
1) ecu tune
2) unretristrict the air intake
3) unrestrict the exhaust
4) diff gears
5) consider weight saving
6) consider engine displacement increase
