Awwesome write up man.. BUt honestly noobs aint going to read all of that..
They want a straight forward and easy to read answer.. E.G.
Extractors - Coby - <site> <price> Power may not increase but response will
Fuel Pump - Bosch 044 - <www.bosch.com> <$350> Big increase in power..
But great write up dude
  • Like 1
i disagree i think noobs will read if, after all you want to know what you are doing with your car and how it makes things better / worst.. not like it takes long to read i know if i invest a lot of money in something i would want to read about it.
Sectioning things is cool tho helps people find what they are looking for rather then reading all through.. like intake mods bang im there and can ignore headers etc..
my 2c half drunk
i agree... i've requested to the admins to get a wikipedia type page to set up.
hopefully we can provide a straight forward and well presented summary, and a link to follow to more detailed explanation.
now i know the title says how to get more power but i was wondering if this would expand and cover other things like suspension components and stuff like that. i like power but im interested into other parts as well, like at the moment im looking for some new springs and thinking of buying some tein springs just to lower it a bit for a better ride height and so i dont get thrown to the other side of the car when just going around a roundabout slowly. so im just throwing something out there and in the end i think it should end up on the main forum page for everyone to see its a brilliant idea.
to my knowledge, with exhausts its a case too small or too big
there is a size that is too small and will restrict power across the rev range (most often the case with factory exhausts systems - the manufacturers wish to keep the noise/vibration/fumes down so as to pass all the necessary tests sufficiently
this is a case of the exhaust being too big a restriction on the engine - ie try blowing through a straw - ur lungs (the engine in this case) have too much gas to force out of the straw, and no matter how hard you try to force it thru, the force of the air out of the straw is pretty much constant)
there is also a size which is to big and will rob power across the rev range (there is not enough backpressure in the exhaust and as a consequence the exhaust gases cool too quickly and just 'sit' in the exhaust pipe
try blowing through a piece of PVC stormwater pipe - your lungs (the engine in this case) run out of gas to push out the end of the pipe - try it, the force of the air coming out the end is barely anything)
Then there is the right size - the pipe is not too small that it restricts heaps, and not too big that it robs; it scavenges - drawing exhaust gases out of the chamber, but having enough pressure to not stagnate and condense in the pipe (think of a didgeridoo - when you blow through it, its not too restrictive, not too big, and resonates which demonstrates a scavenging effect (a high pressure wave is created when the exhaust port closes, then a low pressure wave is created as the port opens, and so on, these pockets of high and low pressure create that scavenging effect), which is very similar to the sound waves created when a didgeridoo is played)
hope i got that right and i hope that makes sense
PS
the right exhaust size is generally not one size, but over a range
then - the smaller the size in the range, generally the better it is low down (up high it just doesn't flow enough and so becomes restrictive); the bigger the size in the range, generally the better it is high up (it is too big @ low rpms as its not flowing enough - high rpms the scavenging affect works well)
PPS
hmmm - im quite proud of that - its the first time ive been able to describe it so that it makes sense :teehee:
this is a quote of mine from a thread a while ago
use it as you see fit....
So what makes sense?
Do share the meaning.. :rofl:
Nothing.. just had a disagreement :O
back to topic IMO! I also would like this thread to have details about handling mods, my car also suffers "round about roll-itus" and if i am taking some corners a bit harder then usual it will just whip back after the body has rolled, whereas my mates car has some hard lowered springs and takes the corners so much smoother. People say lowering to much is bad for handling tho yea? anyone know the best loweredness for cool looks and good handling?
edit: Jarrod's eagle F1's (235's) i bought a while back take the corners so sick :D (compared to what i use to have anyway haha) can keep up with my cousins RS AWD... in the dry at least :rofl:
Edited by 4Door_33GTS
i know what you're saying, but the forum already has a suspension and handling section. the turbo and non-turbo variants share the same (exception R34 Sedan) suspension setups, everything in here would just be a duplicate of what is already available in the appropriate section.
i am myself a suspension and brake nut, however this part of the forum is non turbo.
Nothing.. just had a disagreement :worship:
edit: Jarrod's eagle F1's (235's) i bought a while back take the corners so sick :D (compared to what i use to have anyway haha) can keep up with my cousins RS AWD... in the dry at least :(
too much lowering and it will handle like crap. ideal heights are 355/345mm (front and rear respectively).
some good swaybars should sort out your body roll.
see the suspension thread, sydneykid's bilsteins are top notch. i run them.
let's leave this thread for power applications and things specific to nonturbo shall we?
Quote: Jarrod's eagle F1's (235's) i bought a while back take the corners so sick (compared to what i use to have anyway haha) can keep up with my cousins RS AWD... in the dry at least
MMMMMMMMMMMMMMMMMMMMMMMM i loved those tyres, ill so be getting a set of eagle f1 275 & 265 for the new car when i get the mulla together, damn that thing will grip i love 9" wide rims :P
sounds good mate, i just wasnt sure on if the handling / suspension setup was different because the brakes are.
off to the suspension forum!
brakes are different, you're right that's something to include - most circuit go'ers would be upgrading to turbo items anyway.
sorry about the suspension i wasn't sure if it was the same or not, but now i know so ill definately go there for a bit more info on suspension. by the way id like to recommend upgrading your brakes alot of people neglect them and just look at more power and when you see a high powered car with nice rims but the smallest little brakes ever i find it funny. i recommend upgrading to the turbo brakes they are fantastic my car had them installed when i bought it and it stops very fast and makes you feel more safe. plus they fill the stock rims very nicely and makes it look a hell of alot better. i know its not really a good write up but its a great upgrade for a n/a skyline and should give you peice of mind. just remember if you want more power you still need to stop!
Bah!..
Who needs brakes!?!.. Just change down a gear..
I dont beleive in brakes..
haha - the lighter the car the less brakes you need right???
just down shift and let teh engine do teh slowing right!!!!
seriously brake upgrading is the best thing anybody can do to a car....
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
