i've been whoring the search tool on this forum and i still cant work out an answer.
very rarely the engine check light will come on, and when it does the knock sensor on the pfc reads pretty high. last night drove the car on a cruise for like 2.5hrs and knock sensor read 126 once. @ 4600rpm
during the night only saw it ever got to 40 @ one stage.
thing is i havent hear the engine ping inside the cabin.
some of the boys reckon i was shooting flames last night but thats just fuel dumping right when changing gears?
the car tuned @ racepace last year, and recently was retune there last month. b4 and after its pretty much the same, knock goes off rarely.
mods are TB 3" high flow cat, pod, cooler, 12psi, pfc and walbro fuelpump which is only 3 weeks old.
i'm thinking to get some splitfire coils, anyone got any thoughts?
Edited by eddieeeee-ro
https://www.sau.com.au/forums/topic/194037-pfc-knocking/
if you are not experieicning any pinging, you dont have a plug/coil problem so i woundnt suggest you get splitfires. Knock is really to do with the tune, so your tuner should be able to sort it out for you.
Recieved PM: no probs ;)
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3480321
i was of the belief that since he is not experiencing any detonoation, its merely the pfc knock sensor. ie, something to do with the tune? my bad then
probably is the tune i.e ignition timing advanced too much.
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3480363
The knock readings on the PFC may or may not be actual engine knock. Sometimes a noise in the engine bay at whatever frequency the knock sensors are set to pick up will set them off. Regardless, the terms "pinging" and "knocking" are both detonation.
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3480371
Just go back to Benno with that info mate.
If you tell him 4600rpm, what gear and roughly what load, it'll be one cell that needs adjusting and it wont take long
Also your more likely to notice the one cell at night, as the air is colder. Mine was similar ages ago.
Hit about 80 on a super cold night only around 6000rpm in 3rd, one/two cells changed and happy days ;)
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3480472
Ive had my car tuned a few times,as mods were added.My car sometimes shows knock of 80 for a split second at high boost and RPM.
Taken the car back a few times to sort it out.But i was told all is normal.Could be a number of things in the engine bay making noise.
I never hear any pinging but i do get a read of 80 at high loads on occasion.
Tuner is very reputable.And works mostly on Nissans.
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3481134
I been having same issue, Due to heat. + more boost. + advanced Timing. from the Manual 120(ish) knock indicates Detonation. In agreement with R21Nizmaid, tuner should be able to fix by adjusting the problem cells.. (which I really gotta get done :S).
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3484686
a power fc reading of 125 is false, if it was correct you would definately hear it even if you didnt know what knock is. The knock sensor has picked something else up and like explained above there are many things that create the "frequency" that the knock sensor is tuned to detect, even rocks/pebbles being flung up into the engine bay can set this off.
If you are driving around with the normal max knock sensor of 40 thats ok. Anything around a true knock reading of 80 or so and knocking or pinging whatever you like to call is audible. You'll know when it pings, its a very distint noise.
To make yourself sleep a bit easier, stick it on the dyno and get a pull done just to double check afr's and knock levels
cheers
https://www.sau.com.au/forums/topic/194037-pfc-knocking/#findComment-3484834
