hey, i have a turbonetics turbo rated 600hp on my rb20det s13, 14psi at 5000rpm just is not what im after, looking for maybe 220rwkw with the least lag as possible. was thinking of maybe going rb25 turbo or swapping mine for another.. what do you guys think? what options do i have ? thanks
https://www.sau.com.au/forums/topic/194041-sick-of-this-lag-monster/
oh forgot to mention im on a budget here. Im dreaming if i think someone would swap a 2530 for mine aren't i?
Well its not "that" much more expensive than a hi-flow ($1700) or any other Garrett BB off shelf
second hand hks gt2530 can be had for $1000 to $1500
edit:
this one is brand new (O/H) 1.4k plus shipping so around 1.8k to your door
http://page7.auctions.yahoo.co.jp/jp/auction/g61424467
second hand ones are much cheaper
Edited by [Michael]
Michael thats actually a HKS GT2535 .
If you can find a cheap dead GT2530 (RB type) or a spare exhaust housing thats all it takes to bolt a GT2860RS on an RB six . GT2860RS/GT2530 are very similar compressor wise with the RS being the more modern of the two , both use the same identical turbine .
I'm with Nismoid , off the shelf a GT2530 is difficult to beat on a 2L six .
Cheers A .
Cheers A .
same same, i posted the wrong link sorry lol
Try a MR Turbo Australia / Billet Turbochargers dealer.
There are many options available from bolt on ball bearing high flows to full Billet Turbochargers up grades.
Whats with the advertisement and no technical advice.
This is a technical thread after all :P
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
