I'm pretty sure the globes are all 24 volts in the rear lights
24??? This isn't a truck! The battery will put out 11.8-12v when the car isn't running, and when running the alternator will bring this up to between 13 and 14.4v. The voltage at the taillights is not reduced or boosted at all. just like your headlights... if you have a manual and you chuck it in first, turn on your headlights, and with the brakes on slowly let out the clutch a bit (i.e. stall the engine down to say 300-400RPM) you will notice them all drop in brightness. Only do this for a few seconds so you don't shag out your clutch though! If yours is like mine, and the voltage-regulator is on it's way out, it will drop a little in brightness even jsut idling compared to bringing up the revs a bit.
So short answer? 12V when car is off, 13-14.4V when running.
Thanks...I was just querying it, because i put LED lights in behind my dash in the vl, and worked the resistance on 12V.
This was 440ohm, but only come in 470ohms (closest). if i was to work it off 14.4 then i would have needed about a 560ohm resistor in it. They been in there for 2 years and haven't played up...
I'm working on making the illuminated skyline garnish for the 33, and didn't want to blow up the leds cuz its like 60bucks worth.
I'll just work off 14.4 as it is a safer option. And have worked out that it has the bigger resistors in it.
14.4v - 2.2v =
12.2v
12.2v / 0.075A =
162.66ohm
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
