Software :)
I don't think we will loose her dulcet tones........ what are you doing that she talks to you? LOL.
The only time she talks to me is when i try to run out of fuel i the quest to fill up on Tuesday.
My '01 300GT Premium had her tell me a standard safe driving type of message when I hit the top left button under screen. I also got a noticably slower voice when I hit the nanny meter at 180km/h - always cracked me up - it was like she was talking me off a ledge LOL Where as the normal snappy voice when needing fuel!
  • 4 weeks later...
Good news!
The conversion is complete and they are in the process of testing the software to ensure it is without errors.
We are still working towards a Septemer release so not far away.
Once I have screen shots I will post them up.
We anticipate that you will be able to install the software at home with some simple instructions but this will be confirmed over the next few weeks.
The estimated cost is $200 for the conversion.
I will let you all know when there is an exact time line.
Cheers
Andy
Good news!
Cheers
Andy
Thats is awsome new simple and cheap cant get any better ! Good work Andy !
Im definately down for it. Im in Perth too. Perhaps us Perthies can pay our royalties and catch up for a group firmware update lol
And i only get the jap voice when its over 45 degrees outside - havent heard her otherwise!
JK
Hey Andy it seems theres a bit of interest but people who actually go ahead with it may be a differnt story, is there going to be a limit on these disks ? can they be reused ? If there is going to be a limit maybe you should start getting members to put a small deposit down just a thought.
Once we are ready to go there will not be any limits of the number of conversions we can do and the disc will not be reusable. This will not delay things though as the each conversion disc will be individually created as it will relate to a security code that is created during Disc 1 of a 2 disc install. This is necessary to protect the security of the software that has been created to do this conversion.
I am sure once people see who good this looks I am sure that many people will be happy go ahead.
I would rather wait wait till it is all 100% perfect before we ask for any money. I am taking note of the people who have expressed interest at an early stage and if they are happy to go ahead when they see the final product, I will ensure they are given the opportiunity to be one of the first with the conversion.
Cheers
Andy
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
