I don't think we will loose her dulcet tones........ what are you doing that she talks to you? LOL.
The only time she talks to me is when i try to run out of fuel i the quest to fill up on Tuesday.
My '01 300GT Premium had her tell me a standard safe driving type of message when I hit the top left button under screen. I also got a noticably slower voice when I hit the nanny meter at 180km/h - always cracked me up - it was like she was talking me off a ledge LOL Where as the normal snappy voice when needing fuel!
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4009810
  • 4 weeks later...
Good news!
The conversion is complete and they are in the process of testing the software to ensure it is without errors.
We are still working towards a Septemer release so not far away.
Once I have screen shots I will post them up.
We anticipate that you will be able to install the software at home with some simple instructions but this will be confirmed over the next few weeks.
The estimated cost is $200 for the conversion.
I will let you all know when there is an exact time line.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4064584
Good news!
Cheers
Andy
Thats is awsome new simple and cheap cant get any better ! Good work Andy !
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4064959
Hey Andy it seems theres a bit of interest but people who actually go ahead with it may be a differnt story, is there going to be a limit on these disks ? can they be reused ? If there is going to be a limit maybe you should start getting members to put a small deposit down just a thought.
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4066535
Once we are ready to go there will not be any limits of the number of conversions we can do and the disc will not be reusable. This will not delay things though as the each conversion disc will be individually created as it will relate to a security code that is created during Disc 1 of a 2 disc install. This is necessary to protect the security of the software that has been created to do this conversion.
I am sure once people see who good this looks I am sure that many people will be happy go ahead.
I would rather wait wait till it is all 100% perfect before we ask for any money. I am taking note of the people who have expressed interest at an early stage and if they are happy to go ahead when they see the final product, I will ensure they are given the opportiunity to be one of the first with the conversion.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/6/#findComment-4066632
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
