My quick ramblings...
Not Andy's fault, he's stressing about it more than any of you I bet. Sounds like the programmers are stuffing him around. If they really were interested in doing it they would have at least compiled each CD to match the serial numbers in each of the firmwares of the units. Piracy problem solved. Or used Andy as a distributor. Andy are you even getting a cut? I certainly hope so.
Ok just read this...
His plans are that there will be 2 discs;
Disc 1, will install and produce a unique code that will show on the screen.
That number gets sent to the developer and within 24 hours a the final disc will be ready to download.
Disc 2 is a unique version with the serial number produced from disc 1, encripted in the 2nd disc.
that is the theory, waiting to see the final product.
Cheers
Andy
Why not just get the serial number from the maintenance screen yourself and email it to him to compile the image?
That's not hard to do rather than fartarse around. Can't see anyone changing their rom to pirate the discs if we can't even get the rest working. Has anyone even successfully decompiled their original discs?
Also a long time ago when I was working for a software engineering company with lots of crazy serb programmers who were interested in this project I did look into doing this project. I even called Japan and had a few lengthy conversations with an english speaking guy at xanavi about this just to get some background (Really friendly and accomodating Japs are btw). He basically said that the program was meant to have a function to implement English, but it was released as is at it wasn't important enough to them at the time was the jist of it and they weren't interested in building one for us. But I'm not a business person so if someone wants to put a venture to them.
We've all moved on since then, and I don't really have the time or inclination to be passionately involved, but if someone sends me the 1st disc (not the map disc) that they have(I never got mine) i'll look at it again in my spare time. PM me.
Where are all our software engineers anyway? SAU used to be filled with nerds. I'm happy to pass on what I know.
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
    • I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
    • Which grit sand paper did you use on the pulley btw? Thought I'd ask so I don't scratch it up too much
