Yep. The board crashed (due to a failed RAID controller) and Christian's had to rebuild his database. At first I thought I got kicked out for saying something wrong considering I only just registered the day before! After reading the sticky about the outage, I figured I had to re-register and we're back to normal now, more or less.
rianto has it. and yes they are NOT cheap. not to mention theres still a lot of custom electronics to maintain teh extra options.
Given the composite video input that one can tap into with the V35's, for those who are only concerned with the GPS, I'm thinking one could use the Garmin GVN53 interface as a cheaper alternative. Of course, that would only be an ideal solution for those who don't care much for the stereo and translations. A bit hard for me to tell without a V36 (which won't be until March/April for me) but that's my guess for now. What's your take on this?
up to you. the video in on a 35 has limitations. picture looks a LOT better with RGB applied to it.
I use the GVN53 when I do the 35s. though I use a slightly different version.
if you buy a CKV36 then the full swap is the BEST way to tackle it.
if you read the description they are only installing TV tuner to allow viewing of UK TV Channels. Nothing in the navigation or menus are converted/translated.
its exactly the same to what Chris has been doing, adding an Australian compatible TV tuner.
I think he's still pretty busy... he just finished mine today... I got reverse camera now, although it doesn't tell me 100% whether I'm gonna hit something or not but at least it's helpful to see what's behind me with 150 degree wide angle view....
hm, chris the way you mounted the camera so low, it's very strategic when reversing against a bunch of chics in mini skirts... LOL
    • Too much work, but guess I will have to
    • qld plates “GTR R34” for sale $5500 (listed else where)
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
