OK.....You have asked for pics so here is what I have been able to put together tonight.
The pictures are of the following.
1) Main menu
2) VICS
3) FM
4) Compass & Altitude
5) Fuel Consumption
6) Ave fuel consumption
7) Trip Computer
8) Service information
9) Service detail page (one of 4)
10) ETC
These will give you a good idea of what you will get. There are some more menu's in behind these but bear in mind that the following sections do not function in Australia. VICS, FM, ETC & Navigation.
The real benefit is that on a daily basis all the information you are looking at and using are in English and this is easier to read on the fly and adds to the resale of you car should you decide to sell.
Cheers
Andy
Question Andy,
If you set your service interval to every 500km for example, and you reached the distance,
does the popup alert also gets translated in English, or is it still popping up with Japanese?
Reason i asked is because I still see a little bit untranslated japanese text at the bottom of the screen in picture 2 & 3
Question Andy,
The pop up warnings all come up in English, like the hand brake warning or the the Yellow box that comes up on the TV when you turn the ignition off.
The bits of japanese at the bottom of the screen are the sort of proofing that I am doing over the next 2 weeks. I am that these are corrected if possible.
those bits of text are explanations on the selection on the screen.
I have sent you an email as discussed.
cheers
Andy
looks great... and good work again.
any chance of a definition of the pages that haven't been translated or won't work, what does VICS, FM, ETC mean.
I took a guess but just want to check!
as for the purchase of a V35... always takes me ages to bite the bullet. Deep pockets and short arms!
ETC = Electronic Toll Collection
FM = not 100% what this is used for. Chris Rogers may be able to explain it
VICS = Vehicle Information Control System. This gives information about traffic to the Navi system.
Navi = Navigation system
I believe this is what they do.
From what my rather vague understanding of the Japanese kanji translation FM would be a service (only available in Japan) that allows news-flash or information be displayed on screen, e.g. traffic information, road works, accidents, or perhaps even any general news/advertising.
Even if that screen is translated, it would be of little to no use for us (most likely to no use).
Andy makes a valid point about value in resale. $200 may be a lot of dough to spend for english when most of us can navigate around the screen from habit, but when you go to sell its a much easier pitch to show people in english.
I second that.
There were people asking me info about V35 and they kind of being 'put off' when they learnt that the information screen is all in a language they can't understand.
Just a question about the fuel leaf Andy, In Jap format the leaf goes green upwards as fuel economy (ie fuel used to accelerate) gets better, so goes from 0km/L up to 15km/L. With the inversion to L/Km, how does this work? Does the leaf work backwards towards zero???
Edited by Easy Tiger
You can see how it is in it's worst form from the image.
As you get better economy the coloring of the leaf fades to grey to correspond the the fuel consumption. ie: if you were getting 15L/100, the leaf would be grey above this point and green below the 15L mark.
Cheers
Andy
nothing confirmed yet but we will be working on it soon.
Cheers
Andy
Hi Andy if you dont have anyone from adelaide to help you I might be able to help out. I do alot of firmware and program upgrades for work if thats any help.
thanks Brad,
Give me a few days and I will get back to you about this.
Cheers
Andy
Pics look great Andy. Fantastic to see is all those sections in English. Very nice indeed!
mate, any chance of a less-ugly font?? ;)
hmmm... I see someone doesn't want a conversion and has put himself on the "bitch list" :huh:
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
