hey andy
ill have my car in the sau show and shine
be good to meet you on the day for a chat about what will be involved :)
if you could do it, even better!
haha
-mark
Hi Mark I will see what I can do but the limitation at the moment is the time difference between Russia and Oz. 3pm is about the earliest in the day I can cross paths with Russia to get the install key.
Cheers
Andy
Cheers
Andy
you can obtain a key the day before?
good work Tiger!
and I wish... was going to look more seriously next year however those that consider themselves Management decided to drop a bombshell yesterday... rumours for some time but know they will line their pockets with our money.
good work Tiger!
follow your signature...."if in doubt, go flat out"
one more good news, previously my compass heading was off by about 90 degree.
e.g. i'm heading south but my compass on the screen shows i'm heading west.
Chris told me that the further south of the equator i am, the bigger the issue could be as the gyro was configured for northern hemisphere.
after the english conversion applied, not only it fixed my screen's clock to match melbourne's time, it also fix my compass heading!
now i know where i'm heading if i decided not to use the garmin nav.
I think the developer has done more than just translating the language, good work!
in summary:
- japanese translated to english, most screens including some navigation menus, of course the map wont work
- fuel consumption from km/ltr to ltr/100km the australian way!
- clock display showing australian time
- fixed my compass - i can't confirm this until I see other people's compass that was off and is fixed too after to this conversion.
still a skyline, but yeah $6k turnkey solution on V36 I was told - a swap with 370Z ADM unit.
that may sound steep but anyone who spent $45k+ on a V36 might as well get the navi/tv dept sort out properly if there is an equivalent ADM edition available as a donor part.
in summary:
Ok I had a chat with the developer and just to re-cap some of that above to eliminate any misunderstanding:
- japanese translated to english - YES
- fuel consumption from km/ltr to ltr/100km - YES
- clock display showing Australian time - YES
- fixed my compass - NO - my compass was never 'broken' in the first place, here is what the developer said:
The compass wasn't part of the conversion. The developer said I must have had my car's japanese navigation set to a certain destination in Japan by the previous owner and was somehow set to 'align' with some kind of landmark. That skew the compass off as it will try to align the car to a certain point.
When the conversion is installed it somehow either 'reset' that when I removed the japanese navi dvd to insert the install ROM, or either I have now understand what the japanese navi menu means and was able to turn off that annoying destination that the car kept wanting me to go to in the past year or so.
So if you didn't reset it... you could have gone straight to the previous owner's home?
Cool
:D
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
