Hey guys,
I'm having a bit of issues with mine. I just had the software installed by Andy a couple of weeks ago. Starting yesterday everything started playing up. When I start the car, everything works fine, then about 5 minutes later a message comes on going "Caution do not turn ignition off, do not take disc out" and then another screen 30 seconds later "Insert Program Disc" then like 5 minutes the screen resets itself and starts working again and then another 5 minutes later I get the messages again! Any advice or has anyone else experience this?
Regards,
Hi Gyian
Sorry for this problem. I am just checking with the developer what he wants me to do but we will sort out the problem and most likely reinstall the conversion.
I will get back to you later today when I hear back from him.
Cheers
Andy
Hi Guys,
To save me reading through the 37 pages of this forum can some answer the question im sure you all
have heard 4 million times....
Can following be converted to for here (Melbourne)?
*Nav
*Radio
*Tv
*language
More importantly is there any place in melbourne where i can take it just to do it all??
I have a 2005 v35 350gt 2 door coupe?
thanks heaps
Hi Guys,
*Nav
*Radio
*Tv
*language
thanks heaps
Our language conversion only covers cars to early 2004 at the moment. We are working on later model V35's but it would be mid this year before it will be ready.
Not sure about the rest.
I found TV was a bit of a waste. if I had to go back all over again, I would probably just fit FM band expander on radio and wire the Garmin on the Japanese TV's Aux input. That is probably the only 2 things that I would use pretty much on almost daily basis. Saved me a few hundreds, but since I got it now, I will keep it.
There is a DIY thread on M35 Stagea section showing how to wire Aus TV tuner e.g. Asuka or HiTV unit into the japanese TV tuner's Aux in.
Do a search there. I don't have a direct link, sorry. The basic wiring principle would be similar to V35.
FM band expander any car audio shop can do if you don't want DIY. Otherwise there's lots of ppl who has done it themselves, ask around this forum.
I was told it was just inline connection in the aerial plus finding a +12V and ground. Doesn't need rocket science for that.
I disagree Rianto, the TV tuner is one of the best mods I did. I always listen to the news on the way home and other programs. And the kids love it in the back seats also. :thumbsup:
Thanks for the reply, if you end up working out the 2005 models do you install them? Secondly, how can you have both the tv and nav if theres only 1 input for aux on the system?
once again thanks
once again thanks
when the 2005 model version available I will be doing that as well for Melbourne.
I'm sure it'll all be announced here by Andy when it becomes available.
TV & Nav - thank's to Chris Rogers' "creativity"
On my car it's even complicated because I also have aftermarket reverse camera that overtakes everything on screen as soon as I put it into reverse.
I think I better stop there before my car becomes a rolling Star Trek's USS Enterprise E.
Tempted to wire in a phaser torpedo behind the grill...
Would you do this for me ? For a price of course , I am able to source the Garmin Units through my work.
stop showing off Rianto...
:blink:
all the wiring in my car wasn't done by myself - I know the concept although I never tried to find a +12ve wire before - u should not trust me with wiring in your car.
best if u take it to an audio shop.
i'm sure chris rogers said already garmin is not diy. u could end up in tears if u get it wrong.
    • Too much work, but guess I will have to
    • qld plates “GTR R34” for sale $5500 (listed else where)
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
