even if you replace the hex of japanese texts to english, it will require more work to:
- swap km/ltr consumption to ltr/100km algorithm
change the multiplier, I can't remember the offset off the top of my head, but it's a hex value in the firmware.
Didn't realise the timezone was an issue, but that's just a matter of changing the UTC shift, I'll dig around when I get a chance.
As posted above, if you have no confidence in flashing custom firmwares, then please do not attempt this. It is however almost identical to flashing custom firmware on iPhones and Xboxes etc, so if you've done that in the past this should be straightforward.
I'll see if i can put some screengrabs up, as a visual aid.
I know someone may have brought this up or someone has considered it already but ive got an english conversion on my v35 and was reading that 370z has dvd navigation was just wondering if anyone knows if the map disc is compatible at all? Its probably not even xanvi right? any way just wondering if anyone knew would be good to get it satnav working
Hmmm... this could be fun me thinks... dont have to worry about swapping consumption for economy as i prefer it how it is, so it will just be a case of Translation, char sets and date/time.
In regards to bricking, is there any recovery process if you screw up a hacked firmware? or is it a case of just dont get it wrong?
you can hook a JTAG up and recover, but it's best to try and avoid the situation :P
nope, software engine is different. you are correct in your thinking they are both xenavi but the maps are coded different. easier to adapt it. (which I have done already.)
spare box for one. don't screw up is a better option. JTAG - most of the guys won't know what this is.
lol I'm not sure if I did, but I remember saying "if you can mod an xbox you can flash your xanavi firmware". But yes, finding JTAG pins and flashing etc is very tedious, so best not to attempt it if you're not comfortable with that stuff.
Holy crap, that was a huge read. Followed this thread from start to finish - is that part of the initiation? Picking up a 2003 V35 this week (hopefully) so just wondering who is doing the english conversion? I live near Newcastle, happy to trip down to Sydney. Is that still you Andy? Also, not sure I followed everything with regard to the use of the TV/DVD part of the display. Is that possible? Is that the stuff Chris does? Does anyone do it in Sydney? Or is it better to go for an aftermarket TV/DVD head unit? I get that the SAT/NAV cannot work - not too worried about that.
thanks
thanks
Andy or I can do the conversion for you....I'm in Hornsby.....but then again Shan was doing it for free.....sorry my mistake that was hot air!!!!!...sorry my mistake again his now just explaining how to do it for free at your own risk :)
Yes you can get Chris to do the TV/DVD conversion when your up in QLD.....or you can do the TV yourself and then put a DVD player of some description in that suits.
http://www.skylinesaustralia.com/forums/In...p;hl=tv+install
Edited by Jetwreck
Hi there,
It sounds like the V35 Jap to English conversion is something that a lot of people have been discussing above and that it is now possible. Has anyone tried a conversion for the V36 370GT yet. I would love to be able to read the menus on the screen in English and to get the GPS working would be awesome. Mine has this carwings feature and keeps trying to call the operator in Japan! Wish i could speak Japanese! Car has voice commands for just about everything! :blink:
Getting the GPS working is easy, if you get a Garmin GVN53 you can run this through the AUX. That's the easy way :whoops:
I ran mine through the camera system. I turn on the side mirror camera and flip a switch and it goes to navi. The reason I did this is so I can still listen to music while the nav is running.
  • Like 1
Getting the GPS working is easy, if you get a Garmin GVN53 you can run this through the AUX. That's the easy way :)
Thanks for the reply. That's great info. :D
Use search function to find answer.....
I have used the search feature... (spent 2 whole days reading up on everything that has been done and tried)
I see that people have tried using the 350Z maps etc but i want to use the japan maps but change the data in the map files. (again i haven't seen the map dvd format yet {and cant see one online to download}) but I cant believe you cant reverse engineer them and drop in at least to begin with, the australian map. It might take longer to sub in the roads etc and actually get it to take you places.
the maps are done by Zenrin for Xanavi. If it's like the Toyota ones, then it'll be in Kiwi file format, some of the Chevy guys in the US coded up some opensource decompilers/compilers that might help you. Google should be able to give you some reading material on this.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
