Software :)
  • 5 weeks later...
  • 4 weeks later...
This thread really needs to be part of the FAQ of who can perform the conversions and an update on the progress of software translation for V35 series 2 and V36.
**Sorry guys just read my post again and it may have come across rude, its a Friday afternoon :)
Edited by nezo
Just had my Xanavi translated to english today, thanks to Chris & Simon (& of course the Russians).
The unit wouldn't load from the disc at first but after a drive across a couple of suburbs it mysteriously shook itself into action. The disc was still in so the bumping around probably got the laser working.
The result is pretty good; much easier to use now.
However, what's interesting is that not all info is available after the translation. The reason I know this is that prior to the upgrade, I used to get a warning everytime it powered up that I had an airbag problem. See pic.
I could drill down (from memory thru the maintenance screen) and turn up more info. See other pic.
None of this shows up anymore. I was hoping to see what Nissan thought of my little problem (in English), but nevermind.
So it looks like only the main information made it thru the translation process.
Thanks again guys.
Chris: I have a 2005 V35 series 2 and I wanted to know the time line of English converison kit for my car.
Do you know when this may happen?
Hi
Chris is no longer doing the Xanavi language conversions. He decided it was not worth doing and so Chook does the conversions in Qld now.
But to answer your question, the developer believes he will have the conversion for the Series 2 V35 & M35 by the end of this year. That was the update about 3 weeks ago when I asked.
Cheers
Andy
Hi,
Just wondering can you run a Nissan Maxima or Murano or 370Z head unit on G37?
I'm assuming firmware for those model may able to allow G37's head unit to spit out English (totally speculating here as I know nothing about the software)
Cheers!
Hi,
Cheers!
I have heard that the 370Z unit works and is about $7000 new from Nissan. That was a while ago might be cheaper now like $6500 :D
I saw a 2009 NISSAN MAXIMA RADIO/ NAVIGATION UNIT going for $700USD on ebay so just wondering if I can buy the head unit and swap them over.
I would also like to know
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
    • does anyone know the specs of the R35 master cylinder, rear ratio and knee point? the BM57 is a 0.4 rear ratio with a 435psi knee. I'm looking for someone with a much lower knee pressure. the piston area of the R35 brakes isnt that big so might not work for me but this is interesting.. the other option for me is a GU patrol master cylinder and booster and do the prop valve externally.
    • It sounds like by avoiding maintenance you may be doing more damage than a hypothetical guy in a workshop taking it for a spin. Not sure if you are just being paranoid or things are actually that bad in the US. Find a reputable shop not run by dickheads. Look for people that take pride in their work. Stick around for the day if you have to
