Is this one of the registered V35 AV converter guys - charging NZD$499 for the conversion in NZ?
http://www.trademe.c...n-533190114.htm
Makes me a little bit suspicious since there is a q posted there about a series 2 M35 which should have been a dead giveaway that it wasn't supported, but their initial answer to the q was that it was (they later reported it correctly as not supported).
He is a registered installer.
Cheers
Andy
Sounds a lot more expensive than the indicated price I was given by the previous Auckland based installer when I enquired a year to two back...
I'm still waiting on the S2 M35 conversion, but probably won't be interested if it costs that much. :no:
  • 2 months later...
for those that are buying V36 cars. buy them without navi. I have a drop in solution that uses a Garmin back end and it is TOUCH screen based.
for those that bought cars WITH factory navi. I CANNOT help you.
  • 3 weeks later...
  • 3 weeks later...
Yep, didn't even notice that.
With all the work that has gone into this conversion, why the hell did they f**k up the leaf screen? It wasn't broken to begin with!
I would have though a simple English conversion leaving the km/L calculations/display the same would have been easier.... and more logical
  • 1 month later...
I gotta wonder though. In Japan, aside from the NAVI there would be other features that came with that option pack for the V36. Anyone know what they would have been? I'm drawn to that premium BOSE stereo system for one thing. Anything else?
I got the premium bose in mine. There is a slight diff from what I recollect to the standard bose and for its time 2005 I think the sound is very good and better than most standard fitments of cars its age. The functions are very basic and sure some people want different things out of their unit but as far as sound goes its brilliant !
Bose - better sound through marketing..
I will leave that there..
I find the Bose system lacking alot of mids...hated it when I got the car...my 34 had Focals in there and still sounding so much better even though I only have a 2 way poly.
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
