There is no ignorance to the facts. Nobody is so busy that they can't read through a forum thread that's only 57 pages long. That is all.
Why couldn't ya just simply reply!,
Hay bro, pop over & see pages 45-47.
I only asked for a summary after reading the first 14 pages.
It seemed to be looking good, but dragging on & on, its coming in sep then oct then new year with no end in sight, and another 43 pages to go.
A simple summary, not the earth, Not much to ask for.
youv'e ask for help in the past and will again.
where's the problem.
You're right, I will ask for help, once I'm convinced I've searched through the entire forum in the least if not other forums too. It was in an R32 audio install thread that I found the solution to passing speaker cable through to the doors of my V36. Saved me from asking a repetitive question like you did. I practice what I preach.
But no, poor you was stuck in the abyss of another 43 pages before you found what you wanted. Always the victim but never honest with himself about his laziness.
  • Like 1
  • 4 months later...
Yes, Xanavi site is gone and I no longer do the conversions at all.
There is a company in Sydney doing the language conversions at about 2 times the price I charged.
They have not made any effort to promote them selves so I am not going to do it for them.
  • 4 months later...
  • 5 months later...
for those that find this via google or forum search. I no longer do the lang conversions and have not done so since 2009.
this goes for ANY jap NISSAN vehicle.
in brisbane see PLATINUM VEHICLE SALES in brendale and have your wallet out.
Chris, would you like me to edit your first post to say this service is no longer available?
if you can please. getting 7-8pm calls referring to this post is getting kind of old now :) these cars are at least11-15 yrs old now and most of the hardware in them is either failing or failed and really not worth trying to fix.
  • 3 weeks later...
Calls at that hour? Damn dude, I feel for you. Takes me back to times when I got similar kinds of phone calls at all sorts of hours many a moon ago.
now you know why I got the shits with it. everyone looking for that magic free fix..
  • 10 months later...
On 12/7/2015 at 10:58 AM, xmanz said:
hell ive just ben talking to a guy in aus who says a conversion/gps also for $2500 does starautosound ring any bells,im in nz and have seached here but any likely people dont answer back,this guys says id have to send unit over??
Any one in nz know anything about conversion thnx
I know, I do ;)
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
