There is no ignorance to the facts. Nobody is so busy that they can't read through a forum thread that's only 57 pages long. That is all.
Why couldn't ya just simply reply!,
Hay bro, pop over & see pages 45-47.
I only asked for a summary after reading the first 14 pages.
It seemed to be looking good, but dragging on & on, its coming in sep then oct then new year with no end in sight, and another 43 pages to go.
A simple summary, not the earth, Not much to ask for.
youv'e ask for help in the past and will again.
where's the problem.
You're right, I will ask for help, once I'm convinced I've searched through the entire forum in the least if not other forums too. It was in an R32 audio install thread that I found the solution to passing speaker cable through to the doors of my V36. Saved me from asking a repetitive question like you did. I practice what I preach.
But no, poor you was stuck in the abyss of another 43 pages before you found what you wanted. Always the victim but never honest with himself about his laziness.
  • Like 1
  • 4 months later...
Yes, Xanavi site is gone and I no longer do the conversions at all.
There is a company in Sydney doing the language conversions at about 2 times the price I charged.
They have not made any effort to promote them selves so I am not going to do it for them.
  • 4 months later...
  • 5 months later...
for those that find this via google or forum search. I no longer do the lang conversions and have not done so since 2009.
this goes for ANY jap NISSAN vehicle.
in brisbane see PLATINUM VEHICLE SALES in brendale and have your wallet out.
Chris, would you like me to edit your first post to say this service is no longer available?
if you can please. getting 7-8pm calls referring to this post is getting kind of old now :) these cars are at least11-15 yrs old now and most of the hardware in them is either failing or failed and really not worth trying to fix.
  • 3 weeks later...
Calls at that hour? Damn dude, I feel for you. Takes me back to times when I got similar kinds of phone calls at all sorts of hours many a moon ago.
now you know why I got the shits with it. everyone looking for that magic free fix..
  • 10 months later...
On 12/7/2015 at 10:58 AM, xmanz said:
hell ive just ben talking to a guy in aus who says a conversion/gps also for $2500 does starautosound ring any bells,im in nz and have seached here but any likely people dont answer back,this guys says id have to send unit over??
Any one in nz know anything about conversion thnx
I know, I do ;)
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
