There is no ignorance to the facts. Nobody is so busy that they can't read through a forum thread that's only 57 pages long. That is all.
Why couldn't ya just simply reply!,
Hay bro, pop over & see pages 45-47.
I only asked for a summary after reading the first 14 pages.
It seemed to be looking good, but dragging on & on, its coming in sep then oct then new year with no end in sight, and another 43 pages to go.
A simple summary, not the earth, Not much to ask for.
youv'e ask for help in the past and will again.
where's the problem.
  • Like 1
You're right, I will ask for help, once I'm convinced I've searched through the entire forum in the least if not other forums too. It was in an R32 audio install thread that I found the solution to passing speaker cable through to the doors of my V36. Saved me from asking a repetitive question like you did. I practice what I preach.
But no, poor you was stuck in the abyss of another 43 pages before you found what you wanted. Always the victim but never honest with himself about his laziness.
  • Like 1
  • 4 months later...
Yes, Xanavi site is gone and I no longer do the conversions at all.
There is a company in Sydney doing the language conversions at about 2 times the price I charged.
They have not made any effort to promote them selves so I am not going to do it for them.
  • 4 months later...
  • 5 months later...
for those that find this via google or forum search. I no longer do the lang conversions and have not done so since 2009.
this goes for ANY jap NISSAN vehicle.
in brisbane see PLATINUM VEHICLE SALES in brendale and have your wallet out.
Chris, would you like me to edit your first post to say this service is no longer available?
if you can please. getting 7-8pm calls referring to this post is getting kind of old now :) these cars are at least11-15 yrs old now and most of the hardware in them is either failing or failed and really not worth trying to fix.
  • 3 weeks later...
Calls at that hour? Damn dude, I feel for you. Takes me back to times when I got similar kinds of phone calls at all sorts of hours many a moon ago.
now you know why I got the shits with it. everyone looking for that magic free fix..
  • 10 months later...
On 12/7/2015 at 10:58 AM, xmanz said:
hell ive just ben talking to a guy in aus who says a conversion/gps also for $2500 does starautosound ring any bells,im in nz and have seached here but any likely people dont answer back,this guys says id have to send unit over??
Any one in nz know anything about conversion thnx
I know, I do ;)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
