Ok I was driving out tonight and the compass works BUT it was off by 90 degree...
For example if I am facing South, it will point West, if I am facing east, it wlil point South....
How do I fix this... anyone know if there is a 'sensor' box under the dash that I can perhaps turn sideways 90 degree to fix it?
Easily fixed...
drive Sideways, come on Rianto... think logically man.
It says something here about the tilt angle or dip, and as you progress further into the northern or southern hemisphere the magnetic field will point partially downwards....
So I guess if they set it up to take into account this dip in the northern hemisphere, it would be doing the opposite of what adjustment would be needed in the southern hemisphere.
I had mine up the last night and it was off exactly 180 degrees, that is heading North it pointed to South, heading East it pointed to West, heading West pointed to East. I would think if someone were changing the software it would be fairly easy to swap N and S, and W and E? or maybe turn or flip the unit it is in 180 degrees?
I'm in Perth...
Hi guys... any word/update on the jap to english conversion yet?
On a related note can i just clarify a few things as i'm looking at buying a 350gt in the next few weeks.
I understand that the gps isnt going to be converted, my main concerns are the computer on the premium.
From this thread am i right to assume that the conversion is only planned for the series 1 350gt.
Is there any language conversion done at all on later series??
obviously if late model 350's have no translation planned/possible then i should be looking at a nice condition series 1.
thanks for the help.
If you look a few pages back -Programmer is finalizing software for models up to 10/2004. But depending on demand may look at models thereafter.
I've read through the entire thread, and it looks like the programmer has been finalising the software for quite some time.
As stated, the reason for my interest is that I'm looking to buy a 350GT, and I'm trying to balance the compatibility of a language conversion with getting the newest model possible.
get the newest model possible no question about that. If the language conversion comes through treat it as a bonus no biggie. I've lived with the Jap writings for close to a year now...keeps its import authenticity :D
+1
Got my navi orginal dvds back today -Compass is spot on ! Sounds silly, but I hope people understand "True North"--this why some might think its about 90' out. Also I notice there are several settings (dont underastand them all yet) where you can fix a position and compass adjusts to N,s,e,w of that postion.
But if you check the GPS menu it always is reflects car postion to true north. Boy I dig that groovy japanese voice on the navi also.
The below explains true north from magnetic north. Basically True north is geographical north which is north pole. Whereas magnetic north is effected by the earths magnetic field and axis - is near canada.
http://academic.brooklyn.cuny.edu/geology/...a/magnetic.html
Sorry to complicate things when I posted prev. I meant to add that people often refer to North as the northern part of the city/state rather than either of the above.
I was surprised by the talking too! It was on the first (top button) (mine 11/05 model). Also noticed when you press ETC options it talks when navi disc is in. (instead of chimes when not). Will have to tie my borthers japanese partner in the seat and get her to translate one day !.
Japanese Partner of your brother and she hasn't translated yet?
What's wrong with ya?
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
