  • 4 weeks later...
Did anyone find this screen under diagnostics? What is it?
Tom
Looks like GPS diagnostic data to me - HDOP/GDOP are data values related to predicted GPS error, I'm guessing that the next 3 lines are the signal strengths of the satellites currently in view. The next lot of data looks to be related to an inertial gyro - guess the V35 sat nav must use this as a backup/x-check for the gps data. This quite common for built-in systems, the gyro data means you don't lose your position in a long tunnel and improves accuracy in a city with lots of tall building which can confuse the GPS receiver.
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3570562
  • 3 weeks later...
i am anxiously checking this thread for the solution
pls somebody god help you
There may be a solution. I have made contat with a Russian company that has done the conversion from Jap to Russian. They believe they can do the conversion but will need min customers 20-30 to make it worth while. Then there needs to be someone who can install the firmware. One option send the units (nay above glovebox) to Russia or better is to find a local comany who can work on the units.
Second step is to work out how we get local maps?
The company I have spoken to is http://www.xanavi.ru/cnt.shtml, You can see some of the converted windows on their web site.
A fair way to go but it is a start.
I have had about 5 people so far say they would do it. >_<
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3605147
In regard to the Jap to English ....just as an exercise I have had a play at translating the russian from the russian web site screen shots and here it is. I know I could have gone to the us english site etc but I wanted to try.
A bit obscure I know but ....hey someone may be interested.
See attached file :v35ruskitoengli.doc
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3613009
People,
you may want to check that thread:
http://www.skylinesaustralia.com/forums/M3....html&st=80
I will re-post my message here :
Ok,
guys from Moscow approached me today. They have a "demo" version ready, now they need a brave person in Perth who's got a car DVD based Xanai unit (M35 Stagea or Skyline up to 2005). This gotta be a 2-step proceess:
1) we need to determine the exact version of that unit's unit firmaware and let the guys know
2) they will porvide is with demo (partially translated) version and with original firmware, if that person decides to load the original firmware.
At this stage they are not willing to distribute the demo around the globe :D
screen dumps attached.
Edited by And
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3623155
can someone send me a dump of the japanese firmware? I might be able to translate it to english. I used to do it for a living, recoding japanese software to english.
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3623158
  • 2 months later...
any updates?
The conversion is being worked on at the moment but they are setting up a distributor system for it so they will be paid a fair price for the conversions. The metod of conversion is by installing a disc in the DVD rom and updating the software so the potential for them to do a lot of work and get no return is very real.
I would say by June/July we will have a system set up and a fair price. As soon as I have some more definive dates and costs I will post it up.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3772901
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
