OK.....You have asked for pics so here is what I have been able to put together tonight.
The pictures are of the following.
1) Main menu
2) VICS
3) FM
4) Compass & Altitude
5) Fuel Consumption
6) Ave fuel consumption
7) Trip Computer
8) Service information
9) Service detail page (one of 4)
10) ETC
These will give you a good idea of what you will get. There are some more menu's in behind these but bear in mind that the following sections do not function in Australia. VICS, FM, ETC & Navigation.
The real benefit is that on a daily basis all the information you are looking at and using are in English and this is easier to read on the fly and adds to the resale of you car should you decide to sell.
Cheers
Andy
Question Andy,
If you set your service interval to every 500km for example, and you reached the distance,
does the popup alert also gets translated in English, or is it still popping up with Japanese?
Reason i asked is because I still see a little bit untranslated japanese text at the bottom of the screen in picture 2 & 3
Question Andy,
The pop up warnings all come up in English, like the hand brake warning or the the Yellow box that comes up on the TV when you turn the ignition off.
The bits of japanese at the bottom of the screen are the sort of proofing that I am doing over the next 2 weeks. I am that these are corrected if possible.
those bits of text are explanations on the selection on the screen.
I have sent you an email as discussed.
cheers
Andy
looks great... and good work again.
any chance of a definition of the pages that haven't been translated or won't work, what does VICS, FM, ETC mean.
I took a guess but just want to check!
as for the purchase of a V35... always takes me ages to bite the bullet. Deep pockets and short arms!
ETC = Electronic Toll Collection
FM = not 100% what this is used for. Chris Rogers may be able to explain it
VICS = Vehicle Information Control System. This gives information about traffic to the Navi system.
Navi = Navigation system
I believe this is what they do.
From what my rather vague understanding of the Japanese kanji translation FM would be a service (only available in Japan) that allows news-flash or information be displayed on screen, e.g. traffic information, road works, accidents, or perhaps even any general news/advertising.
Even if that screen is translated, it would be of little to no use for us (most likely to no use).
Andy makes a valid point about value in resale. $200 may be a lot of dough to spend for english when most of us can navigate around the screen from habit, but when you go to sell its a much easier pitch to show people in english.
I second that.
There were people asking me info about V35 and they kind of being 'put off' when they learnt that the information screen is all in a language they can't understand.
Just a question about the fuel leaf Andy, In Jap format the leaf goes green upwards as fuel economy (ie fuel used to accelerate) gets better, so goes from 0km/L up to 15km/L. With the inversion to L/Km, how does this work? Does the leaf work backwards towards zero???
Edited by Easy Tiger
You can see how it is in it's worst form from the image.
As you get better economy the coloring of the leaf fades to grey to correspond the the fuel consumption. ie: if you were getting 15L/100, the leaf would be grey above this point and green below the 15L mark.
Cheers
Andy
nothing confirmed yet but we will be working on it soon.
Cheers
Andy
Hi Andy if you dont have anyone from adelaide to help you I might be able to help out. I do alot of firmware and program upgrades for work if thats any help.
thanks Brad,
Give me a few days and I will get back to you about this.
Cheers
Andy
Pics look great Andy. Fantastic to see is all those sections in English. Very nice indeed!
mate, any chance of a less-ugly font?? ;)
hmmm... I see someone doesn't want a conversion and has put himself on the "bitch list" :huh:
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
