Is this one of the registered V35 AV converter guys - charging NZD$499 for the conversion in NZ?
http://www.trademe.c...n-533190114.htm
Makes me a little bit suspicious since there is a q posted there about a series 2 M35 which should have been a dead giveaway that it wasn't supported, but their initial answer to the q was that it was (they later reported it correctly as not supported).
He is a registered installer.
Cheers
Andy
Sounds a lot more expensive than the indicated price I was given by the previous Auckland based installer when I enquired a year to two back...
I'm still waiting on the S2 M35 conversion, but probably won't be interested if it costs that much. :no:
  • 2 months later...
for those that are buying V36 cars. buy them without navi. I have a drop in solution that uses a Garmin back end and it is TOUCH screen based.
for those that bought cars WITH factory navi. I CANNOT help you.
  • 3 weeks later...
  • 3 weeks later...
Yep, didn't even notice that.
With all the work that has gone into this conversion, why the hell did they f**k up the leaf screen? It wasn't broken to begin with!
I would have though a simple English conversion leaving the km/L calculations/display the same would have been easier.... and more logical
  • 1 month later...
I gotta wonder though. In Japan, aside from the NAVI there would be other features that came with that option pack for the V36. Anyone know what they would have been? I'm drawn to that premium BOSE stereo system for one thing. Anything else?
I got the premium bose in mine. There is a slight diff from what I recollect to the standard bose and for its time 2005 I think the sound is very good and better than most standard fitments of cars its age. The functions are very basic and sure some people want different things out of their unit but as far as sound goes its brilliant !
Bose - better sound through marketing..
I will leave that there..
I find the Bose system lacking alot of mids...hated it when I got the car...my 34 had Focals in there and still sounding so much better even though I only have a 2 way poly.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
