well last night as i pulled up to the local watering hole i got told that i left my lights on.. so walked back to check and find that only my Rear brake lights where on so i got in the car turn the lights on and off and nothing.. so i start it up move it and still they wont turn off, my batt died last night cause i just left it as i was stumped and couldnt really see anything in the dark to rip out fuse's and so on..
any ideas guys?
https://www.sau.com.au/forums/topic/194130-flat-bat/
yea thanks but no help as i dont want to be rip off steerin col since i really dont kno what im looking for, this is really annoyin just jumped the car and got it back to a mates place.. and still cant fig it out
https://www.sau.com.au/forums/topic/194130-flat-bat/#findComment-3481537
I think i might have found the problem where the brake is under the steering col there is a little fuse mod and it seems that the previous owner broke it and put silicone or some sort of apoxi rez to hold it there and its all melted and just fallen out.. going to take the car to japlink and hopefully my warranty covers it cause it bloody better..
https://www.sau.com.au/forums/topic/194130-flat-bat/#findComment-3481867
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
