Hi
i got alot of parts left over.
most of the parts off 2001 R34GTR v-spec2 done 37000km.
R34 GTR V-spec2 Ball bearing turbo $1400
R34 GTR v-spec2 turbo out let pipe $250
R34 GTR V-spec2 intercooler $500
R34GTR V-spec2 Air flow metre $450
R34GTR V-spec2 Airbox $250
R34GTR V-spec2 Radiator $250
R34GTR V-spec2 std BOV with Y-pipe $200
R34GTR V-spec2 FGK exhaust system $650
Brand new Kakimoto N1 exhaust for GTR34 only $1400
Brand New ARC airbox $750
R34GTR Rear Bumper $850
Nismo 320km white face dash with 5000km on it $850
Nismo 320km Black face dash with 60000km on it $750
Nismo carbon snoker $500
R34GTR M-spec Gold suspension $1000
Parts for GTR32/33
ORC 4 plate clutch(done 2000km only) $2600
ARC airbox brand new $750
ARC Air Box used in good condition $500
Titan triple plate clutch push type Fully O/H $2000
Nismo pull type Clutch Fully O/H $1600
GTR33 STD intercooler $350
R33GTR Bolt in Roll cage $600
Endless rear rotors for GTR32(done 10000km) $400
GTR33 S1 airbag steering wheel $300
GTR33 S2 airbag steering wheel $400
R33GTR LH S3 HID head light Good condition $1000
Air flow metre x2 $300
Momo Steering wheel used $120
Momo Wood steering wheel very good condition $240
GTR33 S2 Passenger seat $500
GTR33 STD airbox $200
GTR33 STD alloy wheel $1400
i am in Brisbane
Cheers
Edited by Dave_GTT
  • Replies 54
R34 GTR V-spec2 Ball bearing turbo $1400 - are the wheels ceramic or steel.. wot psi has it been running at??
hi
they are steel wheel
and car only run fatory boost.which is 10psi only.(never running moer than that)
thank you
do you have any pictures of the air boxes, how it looks setup in a 33 GTR?
where abouts in Brisbane?
yes.i will take some pics for the airbox.
this airbox is full aluminum box.and bolt to factory box area.will only fit with factory turbo set up.
and it looks awsome!!
When you say factory turbo setup, you mean factory twins and air intake setup only?
Or could it be made to work with aftermarket bolt on twins and custom air intake pipes?
Im pretty sure then ARC airbox sits in the same spot as the factory box. It uses a ARC panil filter istead of twin pods. it works in conjunction with the factory AFMs.
yes
factory twin turbo set up and can use with after market low mount turbo.
wont fit with twin high mount or big single!!
yeah got it, so if I run twin 2560's it'll be fine? I don't need the AFM's so I'd get custom pipes off the turbos to the airbox made up!
yes.they will fit with twin2560's.just need make the pipe off the turbo.
Stock V-spec II turbos are ceramic wheels, if you care to put a pic of the exhaust side up, I can tell you for sure if they are stock turbos .
since you now know the turbos are ceramic, will you be reducing the price?
Hi
if you are keen.how about pm me how much you willing to pay!!
and there are not many R34 turbo for sale and this is off V-spec2 R34GTR!!
Hi
Ill do a search of the forum later n see how much they go for.. As far as i know, turbos on a v-spec is the same as a standard gtr.. Its only when you get into the N1/NUR GTRs that the turbos are better... I could be wrong :D
Do you have the part/model #?
Edited by Blitz_R33
Ill do a search of the forum later n see how much they go for.. As far as i know, turbos on a v-spec is the same as a standard gtr.. Its only when you get into the N1/NUR GTRs that the turbos are better... I could be wrong :wave:
You are correct but the seller says they are V-spec II so they are younger ( series II GTRS are from late 2000 on ).
  • 3 weeks later...
    • You cut that screenshot a little short; immediately below it  First number is torque in Nm, then in brackets kg-m followed by ft-lb I'm not sure why they provide a range, I have always aimed for about 80% of the top to leave a little room for error
    • I downloaded the gtr r32 manual which I understand will be pretty much same as r34   i rear the page in screenshot and if I understand correctly, the torque for the 4 bolts are 78-98 nm. Why a range?    what does number below it mean( 8-10 ,52-78)?
    • I doubt you'll find someone with specific experience. Any competent mechanic can service it, the motor is same as late 350z.
    • I saw the s15 version but will it be enough force for my clutch? I guess just repairing the booster is the best option
    • recently picked up a very clean example of an NA r34 and want to start dropping in some turbo parts I've got laying around.    Wondering if anyone on here has chucked in a complete GTT Diff - is it straight drop in or will I have headaches? Looking to upgrade to the nismo 1.5way - but I would prefer to use the complete turbo rear end if I'm able.    Also. I have a complete manual conversion here waiting to drop in, but I need to confirm which clutch bearing carrier I need,  Brand new R34 Gtt gearbox with push type conversion. Any solid advice would be greatly appreciated.
