http://www.jsai.com.au/shop/product_info.p...dbbfd8c4b5fd7d9
i found this website and they sell front bar lip for GTR
im going to install that lip underneath the GTT aero front bar
would that fit straight onto it?
and whats the rear pod?
and side skirt will fit on without mod??
cheers
paul
https://www.sau.com.au/forums/topic/194163-would-this-things-will-fit-r34-gtt/
powerplay sells them.. the aero bar needs a special one .. contact powerplay about it.
what do you mean by special one?
the powerplays one is so expensive..
just for that lip is $560..
i dont mind fibreglass for that lip cz its going to be scratched and wont last that long like a front bumper..
im talking about this bar. going to put Vspec lip not this lip..
so will they fit on to this bar?
not sure about the rear pods or side skirt...
couldnt decide yet...
I doubt the GTR lip is a striaght fit onto any Gt-t bars, the GTR has wider fenders and hence wider front bar & bottom lip.
Sheng - i would be very interested to find out if that V-Spec GTR lip fits straight onto the TS bar. Please post pics & let me know when its fitted.
You know that the fibreglass lip wont last as long as a plastic one.
Once you hit something it'll crack straight away. Plastics wont.
Becareful with how low your car is and then adding a lip on.
ok thanks but wouldnt it be too low once you combine topsecrete front bar and a lip?
im not sure which one i should get for side and rear to match front aero GTT bar and the vspec lip.
anyone have recommendation?
I thought about it too, but peter from bodyform got it sorted out :no:
id go for the nismo skirt to match it
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
