RICE DROP 12500 NEEDS EITHER NEW CLUTCH OR CLUTCH FORK
HEAPS OF SPARES EXCELLENT CONDITION CAR JUST CANT AFFORD TO KEEP IT WANT IT GONE
Make: Nissan
Model: Pulsar Gti-R
Milage: 147,000
Transmission: 5spd Manual
Colour: wrc blue
RWC supplied? no
Currently registered? yes
Price: 14,000ono
Contact: Mick on 0431077303
Comments / Modifications:
comes with brand new and uninstalled
-engine hose overhaul kit
-clutch fork
-release bearing
-clutch fork pivot ball
INTERIOR
apexi boost guage, autometer a/f ratio guage, greddy turbo timer, battery relocated to boot, clutch
pedal support bracket, clean standard seats & trim
EXTERIOR
recent respray in WRC Blue with all new rubbers, 17" gmax rims, DBA front & rear slotted rotors,
clear side indicators
ENGINE & DRIVELINE
HYBRID FMIC w/heat wrapped cooler pipes, bosch 984 fuel pump, malpassi rising rate reg w/fuel
pressure guage, 3" full stainless exhaust, Magnaflow muffler, highflow cat, oil catch can, hks pod
filter, turbosmart duel stage boost controler, GFB blow off valve, xtreme lightened alluminium
flywheel, xtreme ceramic 9 puck xtra heavy duty clutch, spark plug cover, whiteline front strut
brace
FOLLOWING PARTS ARE LESS THAN 6000KLMS OLD
clutch fork boot, gearbox thrust bearing, chain tensioner, dizzy cap and rotor button, recon
front driveshafts, clutch slave cylinder, clutch master cylinder, water temp sensor, coolant temp
sensor
XTRAS (SPARES)
used lockwood white face dials, 1x set of arias forged pistons with rings, 2x cylinder heads, 1x
reground cams, 1x standard cams, 2x standard valves pring sets, 2x head bolt sets, 1xrocker
cover, 1x standard bore block, 1x 20thou bored block, 2x sumps, 2x oil pump timing cover
assembly, 2x conrod sets, inlet manifold with plenum, quad throttle bodies, fuel rail with standard
injectors, permaseal full gaskit kit, spare hatch with spoiler and glass, two front bars that need
minor repair, 1x rear bar, standard top mount intercooler, l/h indicator, l/h electric mirror, driver
side door with wind shield, right hand guard, air con condensor, pump and lines, gtir manual on cd,
tail shaft, box of bolts, wiring, bearings and other
stuff.
This car is extremely well maintained and has been serviced every 5000klms with motul oil.i wash
it every w/end and polish it with auto glym polish every 2nd. i always let it warm up before driving.
while i have owned it, best 1/4 mile time 13.121 on 13psi , currently has 172 kw atw on 15.5psi
with dyno sheets to prove, tuned a little rich to be safe so could gain a few extra kw by advancing
timing. good for a high 12 sec pass.
any test or inspection welcome
4months reg comes with the plates LILZLR
doesnt come with rwc but the car should pass easily enough
Images: post-44653-1195369493_thumb.jpg
Edited by LILZLR
  • 1 month later...
RICE DROP 14,000 FIRM NEEDS EITHER NEW CLUTCH OR CLUTCH FORK
CONTACT ME ON 0431077303 MICK
Edited by LILZLR
