Hey guys, just put on a cooler on my 1993 r32 type M.. anyway the front bumper isnt fitting so had to put on an aftermarket one but i want to use the type M bumper to attract less attraction from cops (dont want to have the car looking too flashy) ive been told that i'd have to cut the typeM bumper so that it wuld fit on but too much of it would need cutting, anyone else have suggestions?
oh and with the other bumper i have its a bit damaged, how much would it cost to get it touched up to look new again?
thanks
https://www.sau.com.au/forums/topic/194215-r32-type-m-front-bumper/
I have a R32 GTS4 Type M, Ive got a nice big FMIC in behind mine at the moment. Fitted it all and modded the bar with a mate, pretty much all u need to do is angle grind (best way even though it sounds dodge) the front vent where it comes inward towards the engine bay. I also removed the small verticle middle segment in that front vent and after some checking (make sure ure cooler is pretty much mounted - which i believe yours to be) you can fit it up. Anyone can do it if you take ure time and arn't a retard on the angle grinder. Mine looks stock and perfectly mounted but theres a big FMIC in there. Hope this helps
Cheers.
  • 1 month later...
Hey
You can cut the shit out of the back of the bumper and make it fit.
I got a 600*300 cooler on my car and I was using a stock GTS front bumper, I just cut the back of it and it fitted on perfect.
If you want to get your bumper repaired, cracked/damaged etc I can recommend a guy who does a mint job for a good price.
Let me know how you go.
Abu
Hey Abu,
Yeah thats cool can you PM me the details of that guy? You saw my bumper last time how screwed it was lol. I was thinking of cutting the typeM bumper but now im thinkin ill just get my current front bumper that i got from a friend repaired and just keeping that because it looks alot better so yeah if I can get the details off you that would be great.
Thx
Hey Abu,
Thx
Hahaha not a problem man.
I sent you a PM with the details.
if you want the ultimate solution for a FMIC on a GTSt then what you need is an original GTR bumper
that's the original nissan plastic front bumper - not the cheap fibreglass copiesthat are made for the GTSt but look like GTR bumpers
it bolts to the GTSt without modification, and because the GTR comes standard with a FMIC there is plenty of room for the FMIC you have added
plus, in my opinion, its the BEST looking front that any R32 can have (see picture)
Edited by WazR32GTSt
Hmmm i went to the place Abu recommended but because its fibreglass and theres alot of cracks it pretty much needs to be completely remade with glass which he said would cost about $250. He said it might be a better idea to just buy a new front bumper because it would be around the same price but i havent seen an R32 before with this bumper and it really suits the car which is why i wanted to get it repaired. But now im thinking maybe to just get the original typeM bumper and getting it cut out the back from that bumper place to fit. I dont really know anyone with an angle grinder that can do a proper job for me..
So yeah im just thinking about what to do now. Im not really into the GTR bumper because so many cars have them.
Edit: Attached a few pics of my car.
Edited by cosmokram3r
the thing is, the GTR bumper was actually made to match the rest of the car, unlike the bumper you have now
compare the typeM bumper to the GTR bumper and you will see that it looks like arse in comparison
i bought a second-hand original R32 GTR bumper off the forums for $250 a while back. i know that's cheap, but for even a couple of hundred more you can have the bumper that was designed for that shape and designed to fit a massive FMIC behind it as stock
whatever you do, best of luck.
Hmmmm yeah its definately something to think about, but adam sent me a few pictures of his cut front bar and that looks pretty good so i think ill just go with getting my old Type-M bar from my mates place then getting the back part cut as well as the front mouth where the grills are then just chucking it back on.. that way i can hold off on my respray for a bit while i collect cash because the bar i have on right now is grey so yeah... Ill give that a try first and if it looks good and fits fine ill leave it until i think about getting a new kit maybe a Vertex or something
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
