Hey guys,
Wondering if anyone here has access to a few vector-based images (like CorelDRAW) of tuning brands like Apexi, TRUST, ENKEI, that kinda stuff ?
I know some of you guys are photchop guru’s etc….
I’m in the process of creating stickers etc and need images in a format I can manipulate/scale stuff…
-Kym
If you can hook me up with some stickers you're making (will pay some $), I will get some professional traced in EPS for you, which should be fine for any place to get them done up at any size.
PM me details of what you want and things like that.
Kym, I have all the tuning brand decals in AI EPS format. If your looking to get someone else to print em off for you, get in touch with me, as its actually what I do for a living now ;)
If you have your own plotter im more than happy to let you use my artwork, drop me a PM.
predator: check my website if your intrested in buying some stickers :D
memphis: cheers... will have a look..
man, you even have skylinesaustralia stickers.. u rock.. now why doesn't everybody in VIC have one? we don't even have our own stickers over here :D
In case you need more EPS logos - check these sites out:
http://www.linkclub.or.jp/~yamato77/DL/rok.html
and
http://www.mitsubishi-fto.org/downloads/logos/
I still want the 'PowerFC' one though. Anyone got it as EPS or AI?
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
