hi all... after having my car for around 4 month now and never noticed this ticking sound from the engine when i bought the car...(i thinks the warm weather might have to do with this i think) i have had it checked briefly from a mechanic and he said that it was a exhaust leak from head to manifold and hopefully it's only the gasket not actual manifold crack..... the ticking sound is really noticeable when the engine is cold but the sound gets softer after driving it for a while...(i guess the metal expends with the heat..) and the engine sound seem to be more rough although the idle is consistent....
now my questions is, is it ok to drive the car for a while with the leak? will it do any damage to the car in anyways? (i want to upgrade my exhaust with split dump & front pipe and want to wait until then to fix this problem...)
how much will it be to fix it at a workshop(maybe boostworx)?
Could anyone help me answering these questions would be much appreciated.
cheers, yohan :)
https://www.sau.com.au/forums/topic/194246-exhaust-manifold-leak~/
yeah should be ok to drive around for a little while, but when gaskets start to leak they can tear and will leak further and further around until your car is undriveable eventually.
Round figure for a workshop to remove the turbo, remove the manifold, replace the gasket and put it all back together again is around $300-$500 - it is not a massive job, but is fiddly and can be time consuming. Then you have the risk of nuts being rounded or studs being snapped if they were done up ridiculously tight or have rusted. Then you are up for quite a bit of hard earned if that happens. If you are mechanically minded it is not a difficult job to do yourself - I had never changed a turbo before and I did mine as well as fit a dump pipe and new wastegate actuator - wasn't a hard job really - just time consuming.
i've had a broken stud on my manifold for a while now. I have been checking it every couple of weeks and it isn't leaking yet. My mechanic said it wasn't urgent to fix it due to the low mileage i do.
and i haven't got the time to leave my car at a workshop for a day or 2 to work on it
yeah~ i was thinking about just taking the air box and a few stuff that sits on top of the manifold and tighten the bolts... but i was warried about snapping off the bolts what's been sitting there for 10 or more years and if i did, then i was making a problem even worse....
i have to admit that the engine noise now is horrible to listen to... sound;s like a truck or something :P
i might have to wait until i get the split dump and get all the gaskets changed from manifold to turbo back... that way all the gaskets in the exhaust side are all fresh.
anyone else had similiar problem/experience?
cheers
oh and if it's the actuall manifold, should i be looking at chinging to the stock one or a aftermarket stainless steel one?
unless your going steam pipe then keep the stock one.
most ss ones these days will cause more bad then good.
yeah i hear a lot of SS ones crack too.... so mild steel stock one is the go in a long run i guess...
ah.... i want this fixed.... more money going to the car.... :P
some ss ones are alright. but its hard to filter through the chinese crap to find a good one these days. i dont think they offer any drastic gains over stock anyway, at least not with stock turbo anyway.
arent stock ones cast? or are rb different to sr?
Edited by ted180
It will prob just be the gasket....make sure you get a genuine nissan one, I know the rb25 ones are 110 from main north nissan. I tried aftermarket gaskets and one lasted 4hrs there absolute shite. The stock manifold is cast shouldnt be that.
sinistagtst, did you change the gasket your self? was it hard and time consuming?
another thing is that if i was to change the gastekets i wanna change both head to manifold and manifold to turbo and wanna change all the bolts to new ones as well... where can i get right bolts that are suitable for the job? (strangth wise..)
cheers~
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
